    Need help with internet monitor-module
    20 Posts 5 Posters 10.8k Views 6 Watching
    • D
      duedahlb
      I was wondering if anyone has a solution for this…
      I tried to follow the README file to internet monitor by ronny3050, but i just get a config error…
      Has anyone the solution or a better guide for me?
        schlachtkreuzer6 @duedahlb
        @duedahlb
        Please post your config here (don’t forget to delete your APIs, addresses and any other privacy related info) thanks
        • D
          duedahlb
          The script below is the one i want to put in “top_right” corner
          module: ‘internet-monitor’,
          position: ‘top_center’,
          header: ‘Internet Monitor’,
          config:{
          type: ‘’,
          maxTime: 20000,
          updateInterval: 0,
          verbose: false,
          displayStrength: true,
          displaySpeed: true,
          strengthIconSize: 80,
          maxGaugeScale: 100,
          wifiSymbol:{
          fullColor: ‘#3afc25’,
          almostColor: ‘#ffff0c’,
          halfColor: ‘#ff8c00’,
          noneColor: ‘#ff1111’
          /* Magic Mirror Config Sample
          • By Michael Teeuw http://michaelteeuw.nl
          • MIT Licensed.
          • For more information how you can configurate this file
          • See https://github.com/MichMich/MagicMirror#configuration
          var config = {
          address: “localhost”, // Address to listen on, can be:
          // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
          // - “”, “0.0.0.0”, “::” to listen on any interface
          // Default, when address config is left out, is “localhost”
          port: 8080,
          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
          language: "en",
          timeFormat: 24,
          units: "metric",
          		module: "alert",
          		module: "updatenotification",
          		position: "top_bar"
          		module: "clock",
          		position: "top_left"
          		header: "US Holidays",
          					symbol: "calendar-check-o ",
          					url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
          		module: "compliments",
          		position: "lower_third"
          		module: "currentweather",
          			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
          			appid: "YOUR_OPENWEATHER_API_KEY"
          		module: "weatherforecast",
          		header: "Weather Forecast",
          			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
          		module: "newsfeed",
          		position: "bottom_bar",
          			feeds: [
          					title: "New York Times",
          			showSourceTitle: true,
          			showPublishDate: true
          if (typeof module !== “undefined”) {module.exports = config;}
          • D
            duedahlb @schlachtkreuzer6
            @schlachtkreuzer6 I uploaded the standard file now… and the script module i want to use too
              @duedahlb
              Check your quotes. Change this: ’ to this: " and apply the missing quotes @
              Maxtime
              update … Etc.
              • D
                doubleT Module Developer
                And please check the following link: https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners/2
                Right now, the config.js you posted is near-unreadable.
                • Y
                  yawns Moderator
                  Both schlachtkreuzer6 and doubleT are totally right. I tried to change the post with your config, but akismet.com flags this as spam.
                  Besides wrong quotes the position of your added module was incorrect.
                  Please try this config:
                  MIT Licensed.
                  var config = {
                  address: "localhost",
                  port: 8080,
                  language: "en",
                  timeFormat: 24,
                  units: "metric",
                  		module: "alert",
                  		position: "top_bar"
                  		module: "clock",
                  		module: "newsfeed",
                  			feeds: [
                  		module: "internet-monitor",
                  		position: "top_center",
                  		header: "Internet Monitor",
                  			type: "",
                  			maxTime: 20000,
                  			updateInterval: 0,
                  			verbose: false,
                  			displaySpeed: true,
                  			maxGaugeScale: 100,
                  			wifiSymbol: {
                  				fullColor: "#3afc25",
                  				almostColor: "#ffff0c",
                  				halfColor: "#ff8c00",
                  				noneColor: "#ff1111"
                  D 2 Replies Last reply Reply Quote 1
                  • D
                    duedahlb @yawns
                    @yawns wow, thanks!, but now my screen is just black… tried rebooting:/ anu suggestions?
                    • D
                      Might not be the problem (as modern browser are pretty forgiving about this) but the last property of an object (or array) doesn’t get a trailing comma.
                      Other than that I don’t see any obvious problems. A black screen is better than a config error because it might load the basic MM but just not the modules.
                      Now, what I can suggest and what a developer would do is:
                      • Reduce the config.js to the basics or the originally suggested example.
                      • Add one module after another, always checking if it works or not.
                      • If one doesn’t work or breaks something, note it down, remove it, try the next one. Or figure out directly why it doesn’t work.
                      But that way you can easily point to where it breaks. Everything else is guesswork.
                      • D
                        duedahlb @yawns
                        @yawns it gives me the damn config error… plz help!
                          @duedahlb do you change the quotes and the missing quotes? than upload your config again pls.
                          • D
                            @schlachtkreuzer6 it’s just the standard file, with one extra module…
                             * MIT Licensed.
                            var config = {
                            	port: 8080,
                            	language: "en",
                            	timeFormat: 24,
                            	units: "metric",
                            			module: "alert",
                            			position: "top_bar"
                            			module: "clock",
                            			module: "newsfeed",
                            				feeds: [
                            	    	module: 'internet-monitor',
                                        	position: 'top_center',
                                        	header: 'Internet Monitor',
                                        	config:{
                                            	type: '',
                                            	maxTime: 20000,
                                            	updateInterval: 0,
                                            	verbose: false,
                                            	displaySpeed: true,
                                            	maxGaugeScale: 100,
                            			wifiSymbol:{
                                                		fullColor: '#3afc25',
                                                		almostColor: '#ffff0c',
                                                		halfColor: '#ff8c00',
                            	            		noneColor: '#ff1111'
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @duedahlb
                              @duedahlb
                              did you install the dependencies as per the readme? I just installed this, installed the dependencies, and it fired right up.
                              • D
                                duedahlb @Mykle1
                                @Mykle1 said in Need help with internet monitor-module:
                                @duedahlb
                                yes i did, but i can do it again:)
                                • D
                                  I don’t see any problem with it. But to be on the safe side, I changed the single quotes in the config object for the internet-monitor to double quotes (as the rest of the file), what Schlachtkreuzer said. Again, shouldn’t be an issue – unless it’s conflicting with single quotes in a different place.
                                      config:{
                                          type: "",
                                          maxTime: 20000,
                                          updateInterval: 0,
                                          verbose: false,
                                          displaySpeed: true,
                                          maxGaugeScale: 100,
                                          wifiSymbol:{
                                  What happens if you leave out that module? Does it work then?
                                  Are there any errors listed in the console where you start the mirror? Any errors listed in the browser’s console (if you start it with npm start dev)?
                                    schlachtkreuzer6
                                    Try this
                                        config:{
                                            type: "",
                                            maxTime: "20000",
                                            updateInterval: "0",
                                            verbose: "false",
                                            displayStrength: "true",
                                            displaySpeed: "true",
                                            strengthIconSize: "80",
                                            maxGaugeScale: "100",
                                                    wifiSymbol:{
                                    • D
                                      That doesn’t make sense, the functions are expecting integer and boolean, not strings.
                                      But maybe I found something while checking the module’s readme for the variables and default config:
                                      “Please note that updateInterval has to be greater than maxTime”
                                      https://github.com/ronny3050/internet-monitor
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @doubleT
                                        My config entry:
                                                    config:{
                                                        type: '',
                                                        maxTime: 20000,
                                                        updateInterval: 0,
                                                        verbose: false,
                                                        displaySpeed: true,
                                                        maxGaugeScale: 100,
                                        And my result:
                                        • D
                                          duedahlb @Mykle1
                                          @Mykle1 I got it now! I just reinstalled it, tnx:)
                                          • Mykle1M
                                            @duedahlb
                                            Well done, mate.
