    MMM-voice
    voice control
    329 Posts 55 Posters 970.6k Views 50 Watching
      darrene
      Hmm, I too am getting the ‘Error’ mic icon message, once it finishes its initialisation phase when the mirror starts up.
      I’m started in dev mode - both the web and terminal consoles look clean - the last report I have in the terminal is 'MMM-voice: Starting pocketsphinx, so I don’t know if I should expect anything further messages in that console.
      I’ve taken a look in the MMM-voice/error.log which contains the value ‘127’. It’s repeatable - if i stop the mirror, remove the error log and restart, I get the same results. As a test I’ve tried altering the microphone value in the config.js from it’s initially correct value of 1 - It doesn’t affect the error, which leads me to believe it may not be a hardware issue(?)
      It’s such a shame - all steps reported to have completed okay, the microphone was detected - nothing looks to have been out of the ordinary.
      Is there anything else I can do to test or anywhere else I can look, before I try flattening the SD card and reinstalling?
        darrene @darrene
        progress of a sort…
        tried a sudo apt-get update, followed by a reboot
        same clean startups but between the ‘initialising’ and ‘error’ states I briefly get a ‘no mode found’ and the 127 error is gone - now I just get a 1 returned in the error log
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @darrene
          @darrene no Mode found is the expected behaviour, you can also Enable debug:true this will give You an debug log
            darrene @strawberry 3.141
            @strawberry-3.141 Thanks for following this up. That debug switch is a handy one to know :)
            I’m now running with debug enabled and pouring over the debug log. Forcing a revisit of that portion of the config.js was the best thing I could have done - I realised that I’d left my Microphone testing value set incorrectly before catching some sleep.
            Now that I’ve reset that to ‘1’ - my actual microphone value, as reported by the installer, I no longer get an error.log generated or the onscreen error icon - just the No Mode Detected which is the resting state without debug and an additional ‘undefined’ with debug
            This leads me to believe my problem is a Raspian/hardware one, rather than with the module - If I go into the audio device settings in the desktop, I can see my Logitech USB microphone (ALSA mixer) in the selectable sound cards but am unable to make it the default, which stays as bcm2835 ALSA.
            If I try arecord to test the mic from the terminal, I get
            “arecord: main:682: audio open error No such file or directory”
            however, if I use 'arecord -D plughw:1,0 test.wav
            I get a great wav file recording. Could this be related in some way? I don’t know enough about the code to poke around for the microphone details at this level, to figure out how the installer maps the input device values
              @darrene you’re all good. just try to say your keyword and voice. then you switch from no mode detected to voice mode
              i will propably change that message because you’re not the first one who is confused about no mode detected
              Everyone can send me private messages to debug this module when he/she has a problem, we will then post the result here for everyone.
              To sum up from the private messages I receive, I see a lot of people having issues, because they run the installer multiple times. Make sure you remove ~/MagicMirror/modules/MMM-voice/node_modules, before you run the installer script again.
                darrene
                Thank you! All good - I’m now gong through the words.json - fabulous!
                • G Offline
                  gismo2006
                  At present I try to install the MMM-voice module. I have everything done like it is written in the readme file on Github. Everthing is fine till step3 (installing Pocketsphinx. There is this error: 0_1476473349765_Unbenannt.png In a second try I try what @Nonamexp say (…I’ve tried the command ‘sudo chmod 777 /opt /home/pi/MagicMirror/modules/MMM-voice’ and than ‘bash dependencies.sh’ and it works!) BUT that didn’t work by me. Can someone explain me what happend and what I could do?
                  Greets gismo
                    strawberry 3.141 Project Sponsor Module Developer @gismo2006
                    @gismo2006 this sounds for me that you run the installer more than once right? There is a condition if the directory pocketsphinx exists do git pull and it seems that the branch doesn’t exist anymore. so try to delete the pocketsphinx directory and the node_modules directory in MMM-voice if you have one
                    • G Offline
                      gismo2006
                      @strawberry-3-141 Hi, sorry, but no :-) What Happyend at my First try. Then I try what @Nonamexp post and then I Try your installer again… there are the same problem.
                      But just in this moment durring I write this, I think you wasn`t wrong. I remember I have tested some days ago Alexander and Steven Hicksons Suite. And there I have to install it.
                      I will test, what you write today evening and will post an answer.
                      Thank you for your helping :-)
                        @gismo2006 delete pocketsphinx, sphinxbase and ~/MagicMirror/modules/MMM-voice/node_modules directories and run the installer again, otherwise write me a private message and we will get this running
                        • 6
                        • 32
                        • 33
                        • 4 / 33
