    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 946.7k Views 77 Watching
    • F
      fox
      Hi @Jopyth thank you for your efforts. A question, on mobile device a crazy bug is there. The navigation is not correct because the navigation buttons are not correct and partly dissappeared.
      Does anybode have the same issue?
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
        pepemujica @Jopyth
        @Jopyth Actually I have no idea haha
        I’ve added a link in the module control section where I can change proffiles with the proffile switcher module, so I thought may be something similar could be done
        • F
          fox
          Has anybode an idea why “no modules loaded” ?
          alt text
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @Jopyth
            @Jopyth maybe something like alias
              module: "modulename",
              alias: "fancymodule",
            then check if alias exists if not display normal module name
              pepemujica @strawberry 3.141
              @strawberry-3.141 does the alias exist or it’s just an idea?
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @pepemujica
                @pepemujica well you can put everything in there but alias isnt supported from anything yet, so we could claim it for this and the other configuration modules
                • T
                  twosix
                  The module is not working for me to any extent, when I whitelist the IPs for my school’s wifi (following the HowToWhitelistIP thread’s directions) in every way stated, I get the “this device is not allowed to access…” message. Then, when I allow all IPs access I get the “cannot get remote/html” message. Any help would be great! Thanks!
                  • SnilleS
                    Snille Module Developer
                    Hi! I’m trying to figure out how to hide/show modules with “REMOTE_ACTION” from “MMM-ModuleScheduler”.
                    First, here is the remote control “config”.
                    	module: "MMM-Remote-Control",
                    		"moduleData":[
                    			{"identifier":"module_55_MMM-TextClock"},
                    I know that the “identifier” for the “MMM-TextClock” is correct.
                    Then in the “MMM-ModuleScheduler” I have this:
                    	module: "MMM-ModuleScheduler",
                    		uselock: false,
                    		notification_schedule: [
                    			{notification: "REMOTE_ACTION", schedule: "0 11 * * *", payload: {action: 'HIDE {"identifier":"module_55_MMM-TextClock"}'}},
                    		global_schedule: []
                    It’s suppose to hide the “MMM-TextClock” at 11 AM but it’s not hiding it.
                    I do get this in the log at the correct time:
                    MMM-TextClock received a module notification: REMOTE_ACTION from sender: MMM-ModuleScheduler module.js:115
                    So the action get sent… But the “MMM-TextClock” still shows… What have I missed?
                    Or misunderstood? :)
                    Thank you.
                    • SnilleS
                      Hi again! I’ve been using your excellent module since I started my build. And all along I had it in an “IFrame” on the mirror (the IFrame is shown via a touch on a button MMM-ModuleBar). However, about 2 moths ago, your module no longer shows up in the IFrame (it’s just black on the Mirror). However if I use another browser (not Electron) the IFrame shows the Remote Control. Also it shows up “remotely” both if I go directly to the Remote Control address and if I open the full Mirror in another browser.
                      I’m not sure where the problem is. If it’s on your module or in Electron.
                      I have another “web-interface” (SONOS Web Interface) in another IFrame showed the same way and that still works.
                      I’m on the dev branch of MM.
                      Let me know if you have any ideas… :)
                      • chaseb1357C
                        chaseb1357
                        I downloaded this module today and its been the best one so far. It has everything in it that I have been trying to accomplish for weeks. I wish I saw this one sooner. I have only one issue, when i click the restart MagicMirror button i get an error and my MagicMirror dose not restart.
                        • F
                          fox @chaseb1357
                          @chaseb1357 said in [Remote-Control] Shutdown, Configure and Update your MagicMirror:
                          same to me. this module rocks…! i am for donating with ETH
                          • K
                            krisalexroberts
                            Can you confirm the get URL to hide and show all?
                            • A
                              ArkantosArk
                              @Jopyth
Hi! First of all thanks a lot for creating this awesome module, it really expands the capability of what a Magic Mirror can do.
I just wanted to point out that I had an issue turning on the screen after turn it it off using the module. I went to the “node_helper.js” file to see which function you were using:
 if (query.action === “MONITORON”)
                              exec(“tvservice --preferred && sudo chvt 6 && sudo chvt 7”, opts, function(error, stdout, stderr){ self.checkForExecError(error, stdout, stderr, res); });
                              return true;
                              if (query.action === “MONITOROFF”)
                              exec(“tvservice -o”, opts, function(error, stdout, stderr){ self.checkForExecError(error, stdout, stderr, res); });
                              return true;
                              This function wasn’t really working for me and it seems a bit outdated. You can go further on the reasons why on this links:
https://raspberrypi.stackexchange.com/questions/52042/turning-tvservice-on-and-off-leaves-screen-blank
http://www.elinux.org/RPI_vcgencmd_usage
I just changed that code to:
                              exec(“vcgencmd display_power 1”, opts, function(error, stdout, stderr){ self.checkForExecError(error, stdout, stderr, res); });
                              return true;
                              exec(“vcgencmd display_power 0”, opts, function(error, stdout, stderr){ self.checkForExecError(error, stdout, stderr, res); });
                              return true;
And everything seems to work perfectly for me now. I’m using a Raspberry pi 1 and Midori as a web browser.
My question is, would you be able to implement this changes in order to solve this issue for another users? (and also to keep my same valid configuration in case of an update)
Thanks!
                                Jopyth Moderator
                                I have not been able to work on anything mentioned here, yet, but at least got out a release with a few cool contributions by other people, and a few simple fixes and additions. I do not know when I will be able to look at your questions and issues, but maybe in one or two weeks (especially turning display on and off apparently works much better with the vcgencmd command). If anyone is reading is this in the hopes of finally getting an answer from me, please feel free to post again and remind me, if have not been able to solve it yourself.
                                Here is the change log:
                                [1.1.4] - 2017-09-17
                                Added
                                • Dutch translation
                                • Updating a module tries to install dependencies with npm install
                                • Module identifier is shown if a module is locked with lock strings
                                • Confirmation dialog before restart and shutdown
                                Fixed
                                • Internal save file format and mistakenly hiding modules which were hidden by other modules
                                • Restart should work for new installations
                                Changed
                                • German translation for power menu changed from “Ausschalten” to “Energieoptionen”
                                L P 2 Replies Last reply Reply Quote 0
                                • L
                                  logen563 @Jopyth
                                  @Jopyth Thanks for the update!
                                  • pyrosmileyP
                                    pyrosmiley
                                    So, I’m having a really unexpected bug, where this module somehow negates my custom CSS for the header color of all modules. No idea how/why, but when the page first loads, it’s fine, but as the last of the modules (including this one) load and are activated, the color suddenly snaps back to the default #aaa.
                                    I know for certain it’s this module, since disabling it in the config fixed the header issue. I think this was introduced in the newest update, but I’m not 100% for-sure positive. I do know it started right around the most recent release date though.
                                      pepebc @Jopyth
                                      @Jopyth
                                      Hello, excellent module. I have built the translation file into Spanish: es.json
                                      you want it?
                                        Jopyth Moderator @pepebc
                                        @pepebc Sure. Can you make a PR?
                                        @pyrosmiley Did you start using the brightness adjustment? That definitely overrides brightness of headers and text. Maybe reset to default? That should solve the problem.
                                        pyrosmileyP 1 Reply Last reply Reply Quote 1
                                        • emloweE
                                          emlowe Module Developer
                                          This module is great - a couple items related to support for the ‘official 7" pi touchscreen’
                                          I can probably code this up and submit a PR if you want - the on/off is easy to do because that is already in the helper. Brightness would need to get moved to the helper away from the CSS tricks.
                                          It is interesting that controlling the brightness of a monitor itself over HDMI is surprisingly non-existent, but the 7" touchscreen h/w rev: 1.1 does indeed support direct brightness manipulation:
                                          You can control the brightness of the backlight itself by:
                                          echo X > /sys/class/backlight/rpi_backlight/brightness
                                          where X is a value between 0 and 255
                                          And you can turn off the backlight with
                                          echo 0 > /sys/class/backlight/rpi_backlight/bl_power
                                          and turn it back on with:
                                          echo 1 > /sys/class/backlight/rpi_backlight/bl_power
                                          Earle
                                          • pyrosmileyP
                                            pyrosmiley @Jopyth
                                            @Jopyth I didn’t think I had (actually I don’t think I ever even noticed it!) but I guess I bumped into it just enough to change the value. All good now. Thanks!
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 12 / 14
