    MMM-Globe
    118 Posts 32 Posters 199.1k Views 37 Watching
    • SvenSommerS
      SvenSommer @Eunanibus
      @Eunanibus
      Thanks for you tips. I could easily adjust the module to react to Notifications. I made a pull Request with the latest changes.
      Would be so kind to merge them?!
      I also adjusted my module MMM-GoogleAnalytics to provide the coordinates of the website visitors location.
      The module is in a very early state but it’s quite impressive to see it’s working . See for yourself:
      https://youtu.be/xOU1pVOgcTY
      Bad side of the story?
      I have to get rid of the Raspberry Pi 3 in my MagicMirror. But hey, it was already to long in a “completed” state. :)
      @bhepler : You were running this module smoothly on your mirror. What hardware did you use?
      Looking for some building inspiration?
      Check out my large, thin and metal framed mirror on robstechlog.com.
      Modules released:
      MMM-GoogleAnalytics
      MMM-GrafanaChart
      MMM-GrafanaGauges
      E bheplerB 2 Replies Last reply
      • E
        Eunanibus Module Developer @cowboysdude
        @cowboysdude I’m really pleased. Because of yours and others feedback, I’ve revised the front page of this module recommending not to use this module with Pi’s. That said, I’m really glad it’s serving you well - I worked hard on it and that’s exactly what I wanted from it!
        Also if you want to submit a video of it in action (wherever that may be!) here, please feel free. I love seeing my module in people’s homes.
        • E
          Eunanibus Module Developer @SvenSommer
          @SvenSommer said in MMM-Globe:
          Hi Sven,
          Thanks for your contribution here. I’ll review the changes tomorrow (It’s pretty late here) - I believe @bhepler was using a more powerful linux driven system. I’ve had multiple reports from users that their Pi’s aren’t really up to the task, and I’ve updated the title page as such.
          I’m going to attempt to create a lite version of this module for Pi users when I get the opportunity. In actuality, I’d like to rebuild the module entirely as there’s a lot of code cleanup I’d like to do. Although Rob S was the original creator of the globe, he assisted me in making heavy changes to the code, and I had to make some additions to make it compatible with the MM framework. Unbelievably, this was actually heavier on processing prior to release. Performance improvements are at the top of my list, as are a few other things.
          Either way, I’m really glad your enjoying it, and your creativity in feeding new locations is really encouraging.
          B L 2 Replies Last reply
          • bheplerB
            bhepler Module Developer @SvenSommer
            @SvenSommer I use a Fitlet microPC. Quad core, AMD processor, AMD graphics, 8GB RAM.
              barnosch @Eunanibus
              How is it ongoing with the lite module?
              I would love to see your module on my mirror. Sadly nothing else then a RPi3 is possible at the moment.
              • cowboysdudeC
                cowboysdude Module Developer @barnosch
                @barnosch I have it on my 32" mini itx mirror and it’s awesome! Not to make you feel bad but if the lite version comes out you’re gonna love it!
                  barnosch
                  too late. now i feel bad
                  Already tested it on my Notebook, to see it in real. Very very nice. Thats why i asked.
                  • L
                    ltzChubbz @Eunanibus
                    @Eunanibus Has there been much progress on this lite version? I know there is about 50,000 lines to work through so I’m not expecting anything soon, just wanting an update if possible because I’m a bit tired of looking at this 3fps globe on the rpi3. Thanks heaps for your work
                    • E
                      Hi guys,
                      Apologies for the late response. Unfortunately I’ve started a new software engineering role and my time has been entirely dominated by an array of distractions.
                      While I can only suggest that users of this module do not rely on a Pi, I will endeavour to have a more lighweight, Pi-friendly edition of this module (which should lighten the load for other users too) within the next couple of months. Unfortunately, due to load; I can’t make any promises on deadlines for delivery.
                      I’m having other developers join me in refining the library and tidying up the code quite considerably. Unfortunately, due to the rendering calculations involved, it’s not simply a weekend job. I’m going to do my best to get this completed as soon as possible.
                      Thanks to all users who have helped others with support in technical issues - You’re truly terrific.
                      • cowboysdudeC
                        cowboysdude Module Developer @Eunanibus
                        @Eunanibus just one question… it may have been answered and I didn’t find it but the extra points on the map that are blank… is there a config option to hide those?
                        To only show the coordinates that are in the config.js?
                        SORRY I figured it out :)
                        Again, GREAT mod
                        Thanks!
                          d3r
                          I have been thinking about a work around for to run this on a pi3 because I really want this module on my set up.
                          Would it be possible to render a full rotation(or 5/6 of them) on the pi and output it to a video/gif, then have it play on a loop on the MM?
                          • foxF
                            fox
                            does it work for somebody on a raspi 3?
                            Issues With MMM-WatchDog known?
                            https://forum.magicmirror.builders/post/29827
                            Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                            B 1 Reply Last reply
                            • foxF
                              fox
                              Its better when i switch to Full GL driver on Raspi 3.
                              But the monitor turns on original position? does somebody understand that behaviour?
                              bheplerB 1 Reply Last reply
                              • bheplerB
                                bhepler Module Developer @fox
                                @fox - Yeah. The full OpenGL driver doesn’t respect the display-rotate 1 command in the /boot/config.txt file. The fix for this can be found in the Magic Mirror Wiki.
                                The upshot is edit this file: ~/.config/lxsession/LXDE-pi/autostart
                                and add this line: @xrandr --output HDMI-1 --rotate right
                                  blafpap @fox
                                  @fox got it running on the rpi3, but it is flickering and sometimes blackscreen. Rpi3 is to weak.
                                    domi9522
                                    is there a new module available for the Raspi3+
                                    Thank you
                                      bibi
                                      Still no light version for rpi3?
                                      Otherwise any suggestions about which sbc board (which gpios) would be enough powerful to run this? and of course MM… :upside-down_face:
                                      Mykle1M 1 Reply Last reply
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @bibi
                                        @bibi
                                        The author’s profile states " LAST ONLINE ABOUT A YEAR AGO". You would need hefty graphics. Personally, I wouldn’t try this with less than a laptop board. Good luck and please share your results if you attempt this.
                                        E 1 Reply Last reply
                                        • E
                                          Hey @bibi - I’ve not had any time to take a look at this yet… software engineering and life take over. But maybe it is time to take another look at this. I’m out of the country this weekend, but I’ll try to carve out some time in the next month to take another look at it
                                          • E
                                            Eunanibus Module Developer @Mykle1
                                            @mykle1 I’m always here… always watching 😁
                                            Reply Quote 2
                                            • 4 / 6
