    Failed at the magicmirror@2.2.2 start script 'sh-run-start.sh'
    41 Posts 9 Posters 37.9k Views 8 Watching
    • L Offline
      L_i_v_e @Homerj
      @Homerj i’m desperate, 2 days no result… i’d love an img to flash with everything working… anyone?
      • H Offline
        Homerj
        I have restored an old backup with which it ran with version 2.13 since 01:18 I have no chance to get it to work.
        I have a rp3 with stretch on the run where synonymous fhem over it runs. if any one idea would be great
        • L Offline
          L_i_v_e @Homerj
          @Homerj could you share it?
          • cruunnerrC Offline
            cruunnerr
            @L_i_v_e
            Ok i checked your earlier posts again.
            U did execute the whole stuff as root user. Thats not necessary and even not good!
            I don’t know what else u did as root, but maybe first try to delete the whole MagicMirror Folder and run the command without sudo.
            bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
            Or try a new installation of the raspbian and begin with this (for a full raspbian) or this (for a lite raspbian) tutorial. Do it exactly as its wrote down!
            L 2 Replies Last reply Reply Quote 0
            • L Offline
              L_i_v_e @cruunnerr
              @cruunnerr From when sudo is a bad thing? I’ll try now
              • L Offline
                L_i_v_e @cruunnerr
                @cruunnerr after an auto install without sudo, made it work starting the installation of electron for the 2nd time in it’s folder. Now everything runs smooth if i give him commands but 1:
                -server only does not work, i can’t access it remotely
                -pm2 start does not work, the display goes all black but no module is loaded, it stays black. I tried with both my old config and the example config
                -maybe local launch does not work too? i have no idea since it’s really hard to connect a mouse and keyboard. If i use a VNC can i start it with npm start only?
                any idea?
                cruunnerrC 1 Reply Last reply Reply Quote 0
                  cruunnerr @L_i_v_e
                  @L_i_v_e said in Failed at the magicmirror@2.2.2 start script ‘sh-run-start.sh’:
                  Yes.
                  Since i started my project a few weeks/month ago i have had some trouble, too. But it was all about my inexperience. So at this point im out at all, sorry.
                  Hope someone can help you.
                  But if i said before: Reading the many tutorials and do it like it’s written there brought me to the goal.
                  Only difference to you was, that i was using the early magic mirror versions.
                  Maybe u should give it a last try with Version 2.1.3 and updating later or hoping that there are other guys who can help you. :(
                    carltonb
                    I too have the same problems. In another thread started a few days ago because I have the same issues.
                    Started with Stretch, then went back to an old Jessie Lite version.
                    I have done the automatic install, the manual install, as root and not as root.
                    All fail at the same place. I currently have 5 MM running on PI3, then the update came and tried on one device when it crashed. I will not touch the others until this is resolved.
                    If someone fixes this can they post the steps they used and a link to the image that they used as well.
                    This is getting very frustrating. All my mirrors went together in a matter of an hour or so with no problems. Setting the modules and css is another thing though.
                    Any help is very much appreciated.
                    carltonb
                      cruunnerr
                      Because i am very interested why there are so much problems i will install a complete new Raspbian and MagicMirror. Let me try, i will report soon
                      • L Offline
                        L_i_v_e
                        Please let me know. If you make It work could you share It as an ISO ti flash? Would be so good
                          carltonb
                          I too am keeping abreast of this. I have had 5 installs that went so well that after the update, I can not get it installed.
                          Are we the only ones having problems.
                          Do the install directions need to be changed. Luckily I have backed up every sd card so I am safe, but need to figure out if I do anything to them now (besides the MM upgrade) will they crash.
                            cruunnerr
                            I think i figured out what went wrong ;)
                            i set up a new raspbian (Desktop Version) and could install the MagicMirro without any issues.
                            IMPORTANT:
                            while the installation of MagicMirror (automatic installer) u will see this:
                            Cloning MagicMirror Done!
                            Installing dependencies ...
                            npm WARN deprecated coffee-script@1.10.0: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                            npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                            npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                            > uws@0.14.5 install /home/pi/MagicMirror/node_modules/uws
                            > node-gyp rebuild > build_log.txt 2>&1 || exit 0
                            When u arrived this, it seems the installation is done. But wrong! just wait. it will take some time even if there is no cursor blinking.
                            Just wait and you will see some more installation steps:
                            Wait again:
                            wait again ^^ and u will be asked if u want to use pm2. say YES! :
                            Finally u will see this:
                            And after a few seconds the magic mirror will start automatically and u can enjoy :D
                            Edit:
                            so just to get sure, here are the quick steps i did:
                            1. loaded the newest raspbian stretch with desktop from here
                            2. copy to SD card with ApplePi-Baker
                            3. put an empty file named “ssh” on the boot directory to enable ssh
                            4. start the pi
                            5. via ssh sudo raspi-config
                              set up some configurations like Network-Name, Screen resolution, enabled VNC, expand filesystem etc.
                            6. reboot
                            7. sudo apt-get update ; sudo apt-get upgrade
                              this will take a while
                            8. sudo rpi-update
                              this will take a while, too
                            9. reboot
                            10. bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                            Then just wait! ;)
                              carltonb @cruunnerr
                              @cruunnerr said in Failed at the magicmirror@2.2.2 start script ‘sh-run-start.sh’:
                              VNC
                              No NPM install or other necessary pi setup as listed on the site at Configuring the Raspberry Pi?
                                cruunnerr
                                @carltonb said in Failed at the magicmirror@2.2.2 start script ‘sh-run-start.sh’:
                                Oh sorry, i enabled display rotate in the config. And to disable the screensaver i used sudo apt get install xscreensaver, then via VNC on the Desktop move to the upper left corner (the raspberry button) and go to Preference -> Screensaver and disable it.
                                Maybe use sudo apt-get install unclutter to hide mouse.
                                I just set it up to proof, if there are any issues ^^ So this was a quick install “guide”
                                But yes, there is no extra npm install or something like that necessary.
                                VNC can be enabled with raspi-config
                                edit:
                                oh, and keep in mind that u have to set pm2 to automatically start at reboot.
                                maybe after the first restart after installation finished there is no automatically startet MagicMirror.
                                https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                                L C 2 Replies Last reply Reply Quote 0
                                • L Offline
                                  L_i_v_e @cruunnerr
                                  @cruunnerr lucky you… this is what i got
                                  pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                                  $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                                  $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                                  $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                                  $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                                  $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                                  $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                                  \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                                          \______/
                                  Updating packages ...
                                  Trovato:1 https://deb.nodesource.com/node_9.x stretch InRelease
                                  Scaricamento di:2 http://archive.raspberrypi.org/debian stretch InRelease [25,3 kB]
                                  Trovato:3 http://mirrordirector.raspbian.org/raspbian stretch InRelease
                                  Recuperati 25,3 kB in 11s (2.260 B/s)
                                  Lettura elenco dei pacchetti... Fatto
                                  Installing helper tools ...
                                  Generazione albero delle dipendenze
                                  Lettura informazioni sullo stato... Fatto
                                  build-essential is already the newest version (12.3).
                                  curl is already the newest version (7.52.1-5+deb9u3).
                                  git is already the newest version (1:2.11.0-3+deb9u2).
                                  unzip is already the newest version (6.0-21).
                                  wget is already the newest version (1.18-5+deb9u1).
                                  0 aggiornati, 0 installati, 0 da rimuovere e 0 non aggiornati.
                                  Minimum Node version: v5.1.0
                                  Installed Node version: v9.3.0
                                  No Node.js upgrade necessary.
                                  Cloning MagicMirror ...
                                  Cloning into 'MagicMirror'...
                                  remote: Counting objects: 9010, done.
                                  remote: Total 9010 (delta 0), reused 0 (delta 0), pack-reused 9010
                                  Ricezione degli oggetti: 100% (9010/9010), 11.45 MiB | 19.00 KiB/s, done.
                                  Risoluzione dei delta: 100% (5098/5098), done.
                                  > electron-chromedriver@1.7.1 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
                                  > node ./download-chromedriver.js
                                  > electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
                                  > node install.js
                                  /home/pi/MagicMirror/node_modules/electron/install.js:46
                                    throw err
                                  Error: read ECONNRESET
                                      at _errnoException (util.js:999:13)
                                      at TLSWrap.onread (net.js:629:25)
                                  npm ERR! code ELIFECYCLE
                                  npm ERR! errno 1
                                  npm ERR! electron@1.4.15 postinstall: `node install.js`
                                  npm ERR! Exit status 1
                                  npm ERR!
                                  npm ERR! Failed at the electron@1.4.15 postinstall script.
                                  npm ERR!     /home/pi/.npm/_logs/2018-01-05T20_56_42_584Z-debug.log
                                  Unable to install dependencies!
                                    cruunnerr
                                    did you set it up freshly?
                                    i can’t imagine that you haven’t crashed something before. Please try a new installation of raspbian
                                      carltonb @cruunnerr
                                      @cruunnerr Tried your method on step 10 it took almost 90 minutes to finish!!!
                                      I then went to the page on Auto Starting. Followed the directions. Rebooted.
                                      MagicMirror screen flashed for about 3 seconds, then it went to the desktop for another 3 to 4 seconds then it stopped at the command line.
                                      If I run the logs it tells me
                                      [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                                      /home/carltonb/.pm2/logs/mm-out-1.log last 15 lines:
                                      1|mm       | > magicmirror@2.2.2 start /home/carltonb/MagicMirror
                                      1|mm       | > sh run-start.sh
                                      1|mm       |
                                      1|mm       |
                                      1|mm       |
                                      1|mm       |
                                      1|mm       |
                                      1|mm       |
                                      1|mm       |
                                      /home/carltonb/.pm2/logs/mm-out-0.log last 15 lines:
                                      0|mm       | > magicmirror@2.2.2 start /home/carltonb/MagicMirror
                                      0|mm       | > sh run-start.sh
                                      0|mm       |
                                      0|mm       |
                                      0|mm       |
                                      0|mm       |
                                      0|mm       |
                                      0|mm       |
                                      0|mm       |
                                      /home/carltonb/.pm2/logs/mm-error-0.log last 15 lines:
                                      0|mm       | npm ERR! npm  v3.10.10
                                      0|mm       | npm ERR! path /home/carltonb/package.json
                                      0|mm       | npm ERR! code ENOENT
                                      0|mm       | npm ERR! errno -2
                                      0|mm       | npm ERR! syscall open
                                      0|mm       |
                                      0|mm       | npm ERR! enoent ENOENT: no such file or directory, open '/home/carltonb/package.json'
                                      0|mm       | npm ERR! enoent This is most likely not a problem with npm itself
                                      0|mm       | npm ERR! enoent and is related to npm not being able to find a file.
                                      0|mm       |
                                      0|mm       | npm ERR! Please include the following file with any support request:
                                      0|mm       | npm ERR!     /home/carltonb/npm-debug.log
                                      0|mm       | /home/carltonb/mm.sh: line 1: cd: home/carltonb/MagicMirror: No such file or directory
                                      /home/carltonb/.pm2/logs/mm-error-1.log last 15 lines:
                                      1|mm       | npm ERR! npm  v3.10.10
                                      1|mm       | npm ERR! path /home/carltonb/package.json
                                      1|mm       | npm ERR! code ENOENT
                                      1|mm       | npm ERR! errno -2
                                      1|mm       | npm ERR! syscall open
                                      1|mm       |
                                      1|mm       | npm ERR! enoent ENOENT: no such file or directory, open '/home/carltonb/package.json'
                                      1|mm       | npm ERR! enoent This is most likely not a problem with npm itself
                                      1|mm       | npm ERR! enoent and is related to npm not being able to find a file.
                                      1|mm       |
                                      1|mm       | npm ERR! Please include the following file with any support request:
                                      1|mm       | npm ERR!     /home/carltonb/npm-debug.log
                                      1|mm       | /home/carltonb/mm.sh: line 1: cd: home/carltonb/MagicMirror: No such file or directory
                                      0|mm       | npm
                                      0|mm       |
                                      0|mm       | ERR! Linux 4.9.59-v7+
                                      0|mm       | npm
                                      0|mm       |  ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                                      0|mm       | npm ERR! node v6.12.3
                                      0|mm       | npm ERR!
                                      0|mm       |  npm  v3.10.10
                                      0|mm       | npm
                                      0|mm       |  ERR! enoent ENOENT: no such file or directory, open '/home/carltonb/package.json'
                                      0|mm       | npm ERR!
                                      0|mm       | enoent ENOENT: no such file or directory, open '/home/carltonb/package.json'
                                      0|mm       | npm
                                      0|mm       | ERR! enoent
                                      1|mm       | npm
                                      What step did I miss. It seems not to find the sh run-start.sh file. I am now so confused.
                                      I will see how this sorts out over the weekend and will wait until Monday to try again.
                                        cruunnerr
                                        When u say yes for using pm2 while installation, it will make a MagicMirror process by itself.
                                        type pm2 status
                                        If there is a task called “MagicMirror”, then try:
                                        cd
                                        pm2 stop MagicMirror
                                        pm2 start mm.sh
                                        pm2 save
                                        edit: however i need to say, that 90 minutes is really really much!
                                        The whole installation of the raspbian OS including the MagicMirror took me about one hour
                                        and your mm.sh should look exactly like this:
                                        cd MagicMirror  //here must be a wordwrap. so don't use one line
                                        DISPLAY=:0 npm start
                                        to create this file type in console:
                                        cd
                                        nano mm.sh
                                        adding the lines above and save with “ctrl+x” and “y”
                                        chmod +x mm.sh
                                          Mykle1 Project Sponsor Module Developer @carltonb
                                          npm ERR! enoent ENOENT: no such file or directory, open ‘/home/carltonb/package.json’
                                          Are you sure you are running npm start in the MagicMirror directory?
                                          The error I quoted from your post usually indicates that you are issuing the npm start command from outside the MagicMirror directory. I can reproduce that error when NOT in the MagicMirror directory.
                                            carltonb
                                            Back home and started again.
                                            Ran npm start in the /home/carltonb/MagicMirror directory here is the result
                                            carltonb@clock:~/MagicMirror $ npm start
                                            > sh run-start.sh
                                            npm ERR! Linux 4.9.75-v7+
                                            npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                                            npm ERR! magicmirror@2.2.2 start: `sh run-start.sh`
                                            npm ERR!
                                            npm ERR! Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
                                            npm ERR! If you do, this is most likely a problem with the magicmirror package,
                                            npm ERR! not with npm itself.
                                            npm ERR!     sh run-start.sh
                                            npm ERR!     npm bugs magicmirror
                                            npm ERR! Or if that isn't available, you can get their info via:
                                            npm ERR!     npm owner ls magicmirror
                                            npm ERR!     /home/carltonb/MagicMirror/npm-debug.log
                                            Followed cowboydude instructions for installing. This time it took about 10 minutes to install MM.
                                            What is my next step.
                                            Also thank all of you for taking the time to help a poor soul out.
                                            carltonb
                                            • 2 / 3
