    Failed at the magicmirror@2.2.2 start script 'sh-run-start.sh'
    41 Posts 9 Posters 39.7k Views 8 Watching
      carltonb @cruunnerr
      @cruunnerr said in Failed at the magicmirror@2.2.2 start script ‘sh-run-start.sh’:
      VNC
      No NPM install or other necessary pi setup as listed on the site at Configuring the Raspberry Pi?
      • cruunnerrC Offline
        cruunnerr
        @carltonb said in Failed at the magicmirror@2.2.2 start script ‘sh-run-start.sh’:
        Oh sorry, i enabled display rotate in the config. And to disable the screensaver i used sudo apt get install xscreensaver, then via VNC on the Desktop move to the upper left corner (the raspberry button) and go to Preference -> Screensaver and disable it.
        Maybe use sudo apt-get install unclutter to hide mouse.
        I just set it up to proof, if there are any issues ^^ So this was a quick install “guide”
        But yes, there is no extra npm install or something like that necessary.
        VNC can be enabled with raspi-config
        edit:
        oh, and keep in mind that u have to set pm2 to automatically start at reboot.
        maybe after the first restart after installation finished there is no automatically startet MagicMirror.
        https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
        L C 2 Replies Last reply Reply Quote 0
        • L Offline
          L_i_v_e @cruunnerr
          @cruunnerr lucky you… this is what i got
          pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
          $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
          $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
          $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
          $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
          $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
          $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
          \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                  \______/
          Updating packages ...
          Trovato:1 https://deb.nodesource.com/node_9.x stretch InRelease
          Scaricamento di:2 http://archive.raspberrypi.org/debian stretch InRelease [25,3 kB]
          Trovato:3 http://mirrordirector.raspbian.org/raspbian stretch InRelease
          Recuperati 25,3 kB in 11s (2.260 B/s)
          Lettura elenco dei pacchetti... Fatto
          Installing helper tools ...
          Generazione albero delle dipendenze
          Lettura informazioni sullo stato... Fatto
          build-essential is already the newest version (12.3).
          curl is already the newest version (7.52.1-5+deb9u3).
          git is already the newest version (1:2.11.0-3+deb9u2).
          unzip is already the newest version (6.0-21).
          wget is already the newest version (1.18-5+deb9u1).
          0 aggiornati, 0 installati, 0 da rimuovere e 0 non aggiornati.
          Minimum Node version: v5.1.0
          Installed Node version: v9.3.0
          No Node.js upgrade necessary.
          Cloning MagicMirror ...
          Cloning into 'MagicMirror'...
          remote: Counting objects: 9010, done.
          remote: Total 9010 (delta 0), reused 0 (delta 0), pack-reused 9010
          Ricezione degli oggetti: 100% (9010/9010), 11.45 MiB | 19.00 KiB/s, done.
          Risoluzione dei delta: 100% (5098/5098), done.
          Cloning MagicMirror Done!
          Installing dependencies ...
          > uws@0.14.5 install /home/pi/MagicMirror/node_modules/uws
          > node-gyp rebuild > build_log.txt 2>&1 || exit 0
          > electron-chromedriver@1.7.1 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
          > node ./download-chromedriver.js
          > electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
          > node install.js
          /home/pi/MagicMirror/node_modules/electron/install.js:46
            throw err
          Error: read ECONNRESET
              at _errnoException (util.js:999:13)
              at TLSWrap.onread (net.js:629:25)
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! electron@1.4.15 postinstall: `node install.js`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the electron@1.4.15 postinstall script.
          npm ERR!     /home/pi/.npm/_logs/2018-01-05T20_56_42_584Z-debug.log
          Unable to install dependencies!
            cruunnerr
            did you set it up freshly?
            i can’t imagine that you haven’t crashed something before. Please try a new installation of raspbian
              carltonb @cruunnerr
              @cruunnerr Tried your method on step 10 it took almost 90 minutes to finish!!!
              I then went to the page on Auto Starting. Followed the directions. Rebooted.
              MagicMirror screen flashed for about 3 seconds, then it went to the desktop for another 3 to 4 seconds then it stopped at the command line.
              If I run the logs it tells me
              [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
              /home/carltonb/.pm2/logs/mm-out-1.log last 15 lines:
              1|mm       | > magicmirror@2.2.2 start /home/carltonb/MagicMirror
              1|mm       | > sh run-start.sh
              1|mm       |
              1|mm       |
              1|mm       |
              1|mm       |
              1|mm       |
              1|mm       |
              1|mm       |
              /home/carltonb/.pm2/logs/mm-out-0.log last 15 lines:
              0|mm       | > magicmirror@2.2.2 start /home/carltonb/MagicMirror
              0|mm       | > sh run-start.sh
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              /home/carltonb/.pm2/logs/mm-error-0.log last 15 lines:
              0|mm       | npm ERR! npm  v3.10.10
              0|mm       | npm ERR! path /home/carltonb/package.json
              0|mm       | npm ERR! code ENOENT
              0|mm       | npm ERR! errno -2
              0|mm       | npm ERR! syscall open
              0|mm       |
              0|mm       | npm ERR! enoent ENOENT: no such file or directory, open '/home/carltonb/package.json'
              0|mm       | npm ERR! enoent This is most likely not a problem with npm itself
              0|mm       | npm ERR! enoent and is related to npm not being able to find a file.
              0|mm       |
              0|mm       | npm ERR! Please include the following file with any support request:
              0|mm       | npm ERR!     /home/carltonb/npm-debug.log
              0|mm       | /home/carltonb/mm.sh: line 1: cd: home/carltonb/MagicMirror: No such file or directory
              /home/carltonb/.pm2/logs/mm-error-1.log last 15 lines:
              1|mm       | npm ERR! npm  v3.10.10
              1|mm       | npm ERR! path /home/carltonb/package.json
              1|mm       | npm ERR! code ENOENT
              1|mm       | npm ERR! errno -2
              1|mm       | npm ERR! syscall open
              1|mm       |
              1|mm       | npm ERR! enoent ENOENT: no such file or directory, open '/home/carltonb/package.json'
              1|mm       | npm ERR! enoent This is most likely not a problem with npm itself
              1|mm       | npm ERR! enoent and is related to npm not being able to find a file.
              1|mm       |
              1|mm       | npm ERR! Please include the following file with any support request:
              1|mm       | npm ERR!     /home/carltonb/npm-debug.log
              1|mm       | /home/carltonb/mm.sh: line 1: cd: home/carltonb/MagicMirror: No such file or directory
              0|mm       | npm
              0|mm       |
              0|mm       | ERR! Linux 4.9.59-v7+
              0|mm       | npm
              0|mm       |  ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
              0|mm       | npm ERR! node v6.12.3
              0|mm       | npm ERR!
              0|mm       |  npm  v3.10.10
              0|mm       | npm
              0|mm       |  ERR! enoent ENOENT: no such file or directory, open '/home/carltonb/package.json'
              0|mm       | npm ERR!
              0|mm       | enoent ENOENT: no such file or directory, open '/home/carltonb/package.json'
              0|mm       | npm
              0|mm       | ERR! enoent
              1|mm       | npm
              What step did I miss. It seems not to find the sh run-start.sh file. I am now so confused.
              I will see how this sorts out over the weekend and will wait until Monday to try again.
                cruunnerr
                When u say yes for using pm2 while installation, it will make a MagicMirror process by itself.
                type pm2 status
                If there is a task called “MagicMirror”, then try:
                cd
                pm2 stop MagicMirror
                pm2 start mm.sh
                pm2 save
                edit: however i need to say, that 90 minutes is really really much!
                The whole installation of the raspbian OS including the MagicMirror took me about one hour
                and your mm.sh should look exactly like this:
                cd MagicMirror  //here must be a wordwrap. so don't use one line
                DISPLAY=:0 npm start
                to create this file type in console:
                cd
                nano mm.sh
                adding the lines above and save with “ctrl+x” and “y”
                chmod +x mm.sh
                  Mykle1 Project Sponsor Module Developer @carltonb
                  npm ERR! enoent ENOENT: no such file or directory, open ‘/home/carltonb/package.json’
                  Are you sure you are running npm start in the MagicMirror directory?
                  The error I quoted from your post usually indicates that you are issuing the npm start command from outside the MagicMirror directory. I can reproduce that error when NOT in the MagicMirror directory.
                    carltonb
                    Back home and started again.
                    Ran npm start in the /home/carltonb/MagicMirror directory here is the result
                    carltonb@clock:~/MagicMirror $ npm start
                    > sh run-start.sh
                    npm ERR! Linux 4.9.75-v7+
                    npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                    npm ERR! magicmirror@2.2.2 start: `sh run-start.sh`
                    npm ERR!
                    npm ERR! Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
                    npm ERR! If you do, this is most likely a problem with the magicmirror package,
                    npm ERR! not with npm itself.
                    npm ERR!     sh run-start.sh
                    npm ERR!     npm bugs magicmirror
                    npm ERR! Or if that isn't available, you can get their info via:
                    npm ERR!     npm owner ls magicmirror
                    npm ERR!     /home/carltonb/MagicMirror/npm-debug.log
                    Followed cowboydude instructions for installing. This time it took about 10 minutes to install MM.
                    What is my next step.
                    Also thank all of you for taking the time to help a poor soul out.
                    carltonb
                      carltonb
                      Just discovered that I have two installs of MM one in /home and one at /home/carltonb. Have to figure out why it is installed twice. When I did the bash for the install command I may not have specified directories. I will try again in a few hours.
                        cruunnerr
                        Well, what should i say…
                        I installed the MMM-Podcast a few days ago and had some trouble with it, since it didn’t download newer videos…
                        However, i tried a little bit to get it working (don’t know exactly what i did) and since there i thought it is running like it should.
                        But wrong… it was only working, cause my MMM-watchdog module restarts the mirror automatically 1-3 times a day (Heartbeat timeout).
                        Why am i telling this?
                        Cause i got the exactly same message as you … o.0
                        But different than you, my mirror is working at all except that it restarts some time.
                        First i did what is showing in the message… i updated node and npm Version.
                        node from 6.12.2 to 9.2.1
                        ppm from 3.10.10 to 5.5.1
                        I flushed pm2 logs and now i am waiting if the problem comes up again.
                        Sorry that i can’t help you at all, but i am also trying to figure out what that could be.
                        what OS are you running? Jesse or stretch? lite or desktop version?
                          carltonb
                          Running 2017-07-05-raspbian-jessie. Desktop image.
                          Going to start again and see where I screwed up.
                            carltonb
                            Latest saga, though I am getting frustrated I am learning a lot about the process. I have looked at all the errors that are being given but do not know where to start.
                            If I do a pm2 start mm.sh system gives me a report but nothing happens on my screen.
                            npm-debug.log
                            1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                            2 info using npm@3.10.10
                            3 info using node@v6.12.3
                            5 info lifecycle magicmirror@2.2.2~prestart: magicmirror@2.2.2
                            6 silly lifecycle magicmirror@2.2.2~prestart: no script for prestart, continuing
                            7 info lifecycle magicmirror@2.2.2~start: magicmirror@2.2.2
                            8 verbose lifecycle magicmirror@2.2.2~start: unsafe-perm in lifecycle true
                            9 verbose lifecycle magicmirror@2.2.2~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/carltonb/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/$
                            10 verbose lifecycle magicmirror@2.2.2~start: CWD: /home/carltonb/MagicMirror
                            11 silly lifecycle magicmirror@2.2.2~start: Args: [ '-c', 'sh run-start.sh' ]
                            12 silly lifecycle magicmirror@2.2.2~start: Returned: code: 1  signal: null
                            13 info lifecycle magicmirror@2.2.2~start: Failed to exec start script
                            14 verbose stack Error: magicmirror@2.2.2 start: `sh run-start.sh`
                            14 verbose stack Exit status 1
                            14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
                            14 verbose stack     at emitTwo (events.js:106:13)
                            14 verbose stack     at EventEmitter.emit (events.js:191:7)
                            14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
                            14 verbose stack     at ChildProcess.emit (events.js:191:7)
                            14 verbose stack     at maybeClose (internal/child_process.js:920:16)
                            14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
                            15 verbose pkgid magicmirror@2.2.2
                            16 verbose cwd /home/carltonb/MagicMirror
                            17 error Linux 4.9.75-v7+
                            18 error argv "/usr/bin/node" "/usr/bin/npm" "start"
                            19 error node v6.12.3
                            20 error npm  v3.10.10
                            21 error code ELIFECYCLE
                            22 error magicmirror@2.2.2 start: `sh run-start.sh`
                            22 error Exit status 1
                            23 error Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
                            23 error Make sure you have the latest version of node.js and npm installed.
                            23 error If you do, this is most likely a problem with the magicmirror package,
                            23 error not with npm itself.
                            23 error Tell the author that this fails on your system:
                            23 error     sh run-start.sh
                            23 error You can get information on how to open an issue for this project with:
                            23 error     npm bugs magicmirror
                            23 error Or if that isn't available, you can get their info via:
                            23 error     npm owner ls magicmirror
                            23 error There is likely additional logging output above.
                            24 verbose exit [ 1, true ]
                            pm2 logs
                            0|mm       | No protocol specified
                            0|mm       | npm
                            0|mm       |
                            0|mm       | ERR!
                            0|mm       |  Linux 4.9.75-v7+
                            0|mm       | npm
                            0|mm       |
                            0|mm       | ERR!
                            0|mm       |  argv "/usr/bin/node" "/usr/bin/npm" "start"
                            0|mm       | npm ERR! code ELIFECYCLE
                            0|mm       | npm ERR! magicmirror@2.2.2 start: `sh run-start.sh`
                            0|mm       | npm ERR! Exit status 1
                            0|mm       | npm ERR!
                            0|mm       | npm ERR! Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
                            0|mm       | npm ERR! Make sure you have the latest version of node.js and npm installed.
                            0|mm       | npm ERR! If you do, this is most likely a problem with the magicmirror package,
                            0|mm       | npm ERR! not with npm itself.
                            0|mm       | npm ERR! Tell the author that this fails on your system:
                            0|mm       | npm ERR!     sh run-start.sh
                            0|mm       | npm ERR!
                            0|mm       |  You can get information on how to open an issue for this project with:
                            0|mm       | npm
                            0|mm       |
                            0|mm       | ERR!
                            0|mm       |      npm bugs magicmirror
                            0|mm       | npm ERR! Or if that isn't available, you can get their info via:
                            0|mm       | npm ERR!     npm owner ls magicmirror
                            0|mm       | npm ERR! There is likely additional logging output above.
                            0|mm       | npm ERR!
                            0|mm       |      /home/carltonb/MagicMirror/npm-debug.log
                            PM2        | App [mm] with id [0] and pid [5630], exited with code [1] via signal [SIGINT]
                            PM2        | Starting execution sequence in -fork mode- for app name:mm id:0
                            PM2        | App name:mm id:0 online
                            npm start
                            > sh run-start.sh
                            npm ERR!
                            • el97E Offline
                              el97
                              I had this problem to but i fixed it with npm install electron in the MagicMirror directory.
                                doubleT Module Developer @el97
                                I had this problem the last two days – out of the blue, the MM2 was running for over a year with no problem. I know the thread is old, but it pops up when searching here or on google for this error, so I wanted to add how I was able to solve it:
                                I backed up the config, my modules and my custom css.
                                Then I deleted the MagicMirror-Folder, keeping pm2 and everything unchanged. I cloned MM2, ran “npm install”, brought back the config, modules and custom css and ran “pm2 start mm”.
                                Seems so easy now, but for two days I tried everything – except deleting the folder.
                                • 2 / 3
