    MM and UBUNTU. Made for each other.
    28 Posts 12 Posters 22.3k Views 11 Watching
      barnosch
      Habe you compared the Laptops Power consumption with the raspberries? ;)
      For sure it runs way better, but if you use just normal stuff, it is absolute not necessary imho.
      Most of us use the mirror on the wall, without tons of cables (execpt Power) viewable. With a Laptop you have to be more tricky.
      But nice to know that it runs easily With Ubuntu :D
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @kruemel
        @kruemel said in MM and UBUNTU. Made for each other.:
        And what are your solutions for GPIO related stuff like temperatur sensor or PIR-Sensor (infrared or radar).
        Do you always use the laptop screen or how does this look?
        I don’t need a GPIO solution for temperature sensors. My thermostat already tells me that information. PIR sensor for motion? Not necessary. A simple usb webcam will do the trick. You can use the laptop display or you can use an external monitor when the laptop board supports that. I haven’t seen one that doesn’t.
        kruemelK 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @barnosch
          @barnosch said in MM and UBUNTU. Made for each other.:
          You’re not just running a raspberry. You’re also powering a display. I have not compared but I am sure there is a nominal difference. If there is a difference, the performance boost outweighs the cost difference.
          Normal stuff? There are single modules that the Pi struggles with. I don’t accept stuttering transitions, RAM inadequacies, system overload and heat issues just to use a Pi.
          I don’t know how you speak for “most of us”, but ok. Disassemble the laptop. Fits behind mirror as easily as a Pi. Only the power cord showing. How is this different from a Pi mirror? It’s not.
            pepebc
            Raspberry pi is fine to mount a prototype, but with MM and Kalliope shows freezing moments …
            On the laptop: everything is easy and the answer is immediate.
            My next MM with Kalliope (voice) will be in a mini PC. More expensive, yes, but it compensates the normal fluency that these app requires
            • kruemelK
              kruemel @Mykle1
              @Mykle1 How do you did the wake up with a webcam?
              Let’s say a notebook has always an integrated webcam on top of the display. How do you wake the screen up like a PIR-Sensor does?
              • Mykle1M
                @kruemel
                I use voice commands with Hello-Lucy to put my displays to sleep and to wake them up. I use this on my Pi mirror. https://github.com/alexyak/motiondetector
                  mdhenriksen
                  @Mykle1 Using old laptops makes sense to me too. But i do have one question; how do you manage heat and fan noise? I’m concerned that an old laptop gets hotter than a Pi behind a mirror and if its using a HDD and has a fan it must either get noisy or hot (if you disconnect the fan)
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @mdhenriksen
                    @mdhenriksen
                    I have not found heat to be an issue at all. In fact, by removing the motherboard from the case, the temps are actually lower, even when placed behind a mirror. As long as the construction of the mirror is well ventilated, I don’t think that would ever be an issue.
                    I do not remove the fan. I’ve found that in a normal environment, (people, tv, ambient noises, etc…) the fan noise isn’t even noticeable. Only when the house, or room, is completely silent is the fan audible. For me, this is not an issue when a mobo mirror outperforms any Pi mirror, hands down.
                    Note: There are silent fans these days but I have never used them with a mirror. I’ve never felt the need to but that is certainly an option for anyone.
                      mdhenriksen @Mykle1
                      @mykle1 said in MM and UBUNTU. Made for each other.:
                      @mdhenriksen
                      Nice to know! Got a old laptop I’m gonna try it with then! Using MMM-pages and MMM-voice, so a more powerful CPU would be preferred.
                      • Mykle1M
                        @mdhenriksen said in MM and UBUNTU. Made for each other.:
                        That is largely the reason I moved away from the Pi. (I still have my first Pi mirror). I’ve been using MMM-voice and Hello-Lucy for about a year now and I could not be more pleased with the results and the performance.
                        • bheplerB
                          bhepler Module Developer
                          I did learn the hard way that a miniPC running an Intel Atom processor and integrated graphics is not suitable for Ubuntu and therefore the MagicMirror. The IGP does not have drivers in Ubuntu 14, 16, nor 18 and uses most of its power to render the desktop.
                          I might put the server version on it and turn it into a gateway or something.
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @bhepler
                            @bhepler said in MM and UBUNTU. Made for each other.:
                            The only two laptops that I’ve had trouble with are both ThinkPads. I struggled with them and eventually gave up.
                            However, I did have success with a little piece of $h1t with specs similar to what you mentioned.
                            https://www.youtube.com/watch?v=QZ8t3UoKYu0
                            Total cost = $11
                            Specs:
                            ASUS Eee PC
                            Intel Atom CPU N570 @ 1.66GHz x 4
                            2GB of RAM
                            Intel Pineview M Graphics
                            Display 8.5" width by 5.25" height
                            250GB HD
                            Integrated microphone
                            Built-in WiFi
                            VGA port (for external monitor)
                            $11 on craigslist
                            64-bit Ubuntu 14.04 LTS
                            MagicMirror v2.1.3
                            Modules:
                            MMM-Advice
                            AlarmClock
                            calendar
                            clock
                            compliments
                            Cocktails
                            EARTH
                            EasyBack
                            Events
                            FMI (Find My iPhone)
                            ImageSlideshow
                            Lunartic
                            newsfeed
                            NOAA3
                            PC-Stats
                            voice w/ Hello-Lucy
                            WunderGround
                            bheplerB 1 Reply Last reply
                            • bheplerB
                              bhepler Module Developer @Mykle1
                              @mykle1 - Sigh. I suppose I can try again. Did you have to do any fiddling to get the OS to use a graphics driver?
                              • Mykle1M
                                No sir. I did a standard install of ubuntu 16.04LTS (I only use this version. I tried 18.xx and had trouble) During the setup of the installation there is a click box for “use third party drivers” or something to that effect. I always click (enable) that option. I don’t know if it’s worth mentioning but I always use a wired internet connection during installation. It’s just faster that way as it updates everything.
                                Let me know how you make out. :thumbsup:
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @Mykle1
                                  Recommendation Update
                                  Actually, this is more of a recommendation confirmation. While you can use ubuntu 18.xx and MM together, I don’t recommend it. I just did a clean install of ubuntu 18.04. Newest stable node and npm. MM v2.6.0. Yes, it runs MM but I don’t see any benefit to using ubuntu 18.xx over 16.04 LTS. I don’t like the changes to the UI in 18.xx and I really don’t like dealing with all the vulnerabilities.
                                  Ubuntu 16.04 LTS has a more intuitive UI (IMHO) and there are NO vulnreablilities to deal with. NONE!
                                  So, for the time being, I’m staying with Ubuntu 16.04 LTS. It’s trouble free and MM loves it, too.
                                  I did a test install of Ubuntu 18.04 on a machine I found in someone’s trash. That’s when the vulnerabilities reminded me of why I don’t like 18.xx. Look at the specs. One man’s trash is another man’s treasure.
                                  justjim1220J 2 Replies Last reply
                                    batfastard
                                    not gonna lie, i actually have a i5 mini pc laying around and have been fiddling with the pis for weeks now trying to get everything dialed in and your post got me a little pumped to be able to use this pc i got.
                                    i got ubuntu installed no problem…
                                    i know NOTHING about it so i couldnt even get past how to install the wireless adapter lol…
                                    so im scrapping this and going back to install raspbian on the pc and will try it at that point.
                                    • justjim1220J
                                      justjim1220 Module Developer @Mykle1
                                      @Mykle1 Nice Find! :)
                                      Jim Hallock - 1995
                                      • justjim1220J
                                        @Mykle1
                                        I had version 18.xx installed, up and going just fine on my dev machine
                                        I am used to dealing with vulnerabilities, since I mainly work with Windows
                                        But, I just have my mindset to run npm audit fix --force & npm i lodash@4.17.5 -g & npm i acorn@^6.0.0 -g after every install of MM2. only takes a few minutes extra and it fixes all the vulnerabilities. Except for a few that come with some of the modules. With Ubuntu 18.xx, if I remember, I think just the npm audit fix --force was all I needed to do.
                                        Jim Hallock - 1995
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @justjim1220
                                          @justjim1220
                                          Yes, as I said, I too had ubuntu 18.xx and MM up and running. I just prefer NOT to deal with any vulnerabilities which 16.04 doesn’t have. I don’t know of any benefit to running 18.xx over 16.04 and, as I stated, I’m not a fan of the new UI in 18.xx. I ran MM over Windows when I first started. The disadvantages quickly became apparent. Hello-Lucy never would have happened if I didn’t leave Windows behind. I never looked back. :-)
                                          • Mykle1M
                                            By popular demand
                                            Install ubuntu 16.04LTS (internet connection HIGHLY recommended)
                                            You MUST (check box) “Install 3rd Party Drivers” during installation
                                            Fully update the installation via the software manager after installation (It often needs to)
                                            Install node (includes npm) (I use node 8 )
                                            1. curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
                                            It will ask you if you want to install curl (gives you the command). Do so. Then run #1 again
                                            1. This will complete the installation of node and npm
                                            sudo apt-get install -y nodejs
                                            1. Check for success of node and npm installation in your terminal.
                                            run node -v (this will show your version)
                                            run npm -v (this will show your version)
                                            Now install MM
                                            Run git clone https://github.com/MichMich/MagicMirror.git in your terminal
                                            You may be asked to install git here. Do so. Use the command presented to you in the terminal
                                            Then run git clone https://github.com/MichMich/MagicMirror.git again
                                            Then cd MagicMirror and run npm install
                                            Then run your mirror npm start
                                            Reply Quote 3
