    MMM-Globe
    119 Posts 39 Posters 235.7k Views 40 Watching
      chris1971
      would be great!!!
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @chris1971
        @chris1971
                    module: 'MMM-Globe',
                    position: 'middle_center',
                    style: 'europeDiscNat',
                    imageSize: 600,
                    ownImagePath:'https://eumetview.eumetsat.int/static-images/MSG/RGB/NATURALCOLOR/FULLRESOLUTION/IMAGESDisplay/VazIBqHF9k665',
                    updateInterval: 10*60*1000
        I hope this ok for you…
          Stoffbeuteluwe Project Sponsor @Stoffbeuteluwe
          @Stoffbeuteluwe ist that ok?
            chris1971
            Great!!!
            It’s working with the link… where did you find it?
            Regards, Christoph
              @chris1971 this is the link from the picture of the Earth on the eumesat webpage…
                chris1971
                yes - and now I still have the question if the picture will be updated automatically. With the old configuration (on the EUMETSAT server) I got a new picture every 15 minutes…
                  @chris1971 i hope so
                    chris1971
                    until now - no update… still the same picture since 2 hours…
                      Mykle1 Project Sponsor Module Developer @chris1971
                      @chris1971
                      If you are using . . .
                      . . . then that address would need to update with a new picture for the module to retrieve and display it. If that address is a static picture then the module will only be able to display that.
                        Stoffbeuteluwe Project Sponsor @Mykle1
                        @Mykle1 perfekt thank you …
                          chris1971
                          I replaced the own image path in the css with “http://gif.keraunos.org/nuageseu.gif”.
                          The part of the css is looking now:
                          	imageSize: 500,
                          	ownImagePath:'http://gif.keraunos.org/nuageseu.gif',
                          	updateInterval: 1*60*1000 // ervery 2 minutes
                          It’s not a real globe, but a good animated gif for the weather forecast with clouds…
                          • saljokeS Offline
                            saljoke
                            I replace the URL own image path with https://eumetview.eumetsat.int/static-images/latestImages/EUMETSAT_MSG_RGBNatColourEnhncd_LowResolution.jpg
                            There are different of quality but is the better I found
                              shgmongohh @saljoke
                              @saljoke
                              I also replaced the URL but the image doesn´t update.
                              Has anybody a solution, how to update the image automatically?
                                     ownImagePath:'https://eumetview.eumetsat.int/static-images/latestImages/EUMETSAT_MSG_RGBNatColourEnhncd_LowResolution.jpg',
                                sdetweil @shgmongohh
                                @shgmongohh said in MMM-Globe:
                                EUMETSAT_MSG_RGBNatColourEnhncd_LowResolution.jpg’
                                  shgmongohh @sdetweil
                                  I don´t think that it is static. Every hour the picture is updated with the same adress.
                                  I thought that Globe updated the picture with the update intervall.
                                    jhoney Banned
                                    Cool and interesting! Im gonna try it out and see how it works.
                                      Mykle1 Project Sponsor Module Developer @shgmongohh
                                      Well, if that is the case then it should update the image in the module. I don’t use this module. Perhaps someone that does use it will chime in with there findings, or fixes.
                                      • FlatPepsiF Offline
                                        FlatPepsi
                                        I see in the latest code that it is appending the date & time to avoid caching.
                                        I’ve added a number of console log messages to the code, and it looks like it’s never refreshing. Can anyone confirm that MMM-Globe really does refresh for them, after the initial page load?
                                        I’ve temporarily switched my mirror to MMM-iFrameReloaded, which does indeed refresh, but doesn’t scale the image to the size I need.
                                          Stoffbeuteluwe Project Sponsor @FlatPepsi
                                          @FlatPepsi it is not working…
                                            dhruvgami1989
                                            B StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                                            • 6 / 6
