    MMM-Globe
    119 Posts 39 Posters 239.8k Views 40 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @chris1971
      @chris1971
      If you are using . . .
      ownImagePath:'https://eumetview.eumetsat.int/static-images/MSG/RGB/NATURALCOLOR/FULLRESOLUTION/IMAGESDisplay/VazIBqHF9k665',
                  updateInterval: 10*60*1000
      . . . then that address would need to update with a new picture for the module to retrieve and display it. If that address is a static picture then the module will only be able to display that.
      StoffbeuteluweS 1 Reply Last reply
      • StoffbeuteluweS
        Stoffbeuteluwe Project Sponsor @Mykle1
        @Mykle1 perfekt thank you …
          chris1971
          I replaced the own image path in the css with “http://gif.keraunos.org/nuageseu.gif”.
          The part of the css is looking now:
          module: 'MMM-Globe',
          position: 'middle_center',
          	style: 'europeDiscNat',
          	imageSize: 500,
          	ownImagePath:'http://gif.keraunos.org/nuageseu.gif',
          	updateInterval: 1*60*1000 // ervery 2 minutes
          It’s not a real globe, but a good animated gif for the weather forecast with clouds…
          • saljokeS
            saljoke
            I replace the URL own image path with https://eumetview.eumetsat.int/static-images/latestImages/EUMETSAT_MSG_RGBNatColourEnhncd_LowResolution.jpg
            There are different of quality but is the better I found
              shgmongohh @saljoke
              @saljoke
              I also replaced the URL but the image doesn´t update.
              Has anybody a solution, how to update the image automatically?
                     ownImagePath:'https://eumetview.eumetsat.int/static-images/latestImages/EUMETSAT_MSG_RGBNatColourEnhncd_LowResolution.jpg',
                sdetweil @shgmongohh
                @shgmongohh said in MMM-Globe:
                EUMETSAT_MSG_RGBNatColourEnhncd_LowResolution.jpg’
                  shgmongohh @sdetweil
                  I don´t think that it is static. Every hour the picture is updated with the same adress.
                  I thought that Globe updated the picture with the update intervall.
                  Mykle1M 1 Reply Last reply
                    jhoney Banned
                    Cool and interesting! Im gonna try it out and see how it works.
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @shgmongohh
                      Well, if that is the case then it should update the image in the module. I don’t use this module. Perhaps someone that does use it will chime in with there findings, or fixes.
                      • FlatPepsiF
                        FlatPepsi
                        I see in the latest code that it is appending the date & time to avoid caching.
                        I’ve added a number of console log messages to the code, and it looks like it’s never refreshing. Can anyone confirm that MMM-Globe really does refresh for them, after the initial page load?
                        I’ve temporarily switched my mirror to MMM-iFrameReloaded, which does indeed refresh, but doesn’t scale the image to the size I need.
                        • StoffbeuteluweS
                          Stoffbeuteluwe Project Sponsor @FlatPepsi
                          @FlatPepsi it is not working…
                            dhruvgami1989
                            bheplerB StoffbeuteluweS 2 Replies Last reply
                            • bheplerB
                              bhepler Module Developer @dhruvgami1989
                              @dhruvgami1989 - I wonder if the globe image is pushing the upper three regions higher? I have a couple things to try, but I don’t have a solution really.
                              • Turn off the compliments temporarily and put the globe module in lower_third.
                              • Reduce your globe image size and see if the weather forecast reappears
                              • Move the globe to full_screen below, which should remove it from the shuffling that comes with the module positions.
                              I hope one of these works for you.
                              Reply Quote 2
                              • StoffbeuteluweS
                                Stoffbeuteluwe Project Sponsor @dhruvgami1989
                                @dhruvgami1989 my current weather appears after 10 minutes but I don’t know why.
                                Does your globe module update the Picture?
                                My globe module does not update.
                                D 1 Reply Last reply
                                Reply Quote 2
                                  dhruvgami1989 @Stoffbeuteluwe
                                  @Stoffbeuteluwe Thanks for the tip. It came up exactly after 10 mins! Very weird. And no, the globe does not update
                                    JHerndon
                                    @dhruvgami1989 [unrelated] how do you use a private google calendar with a user/pass setup? I haven’t been able to find a tutorial for this.
                                    bheplerB 1 Reply Last reply
                                    • bheplerB
                                      bhepler Module Developer @JHerndon
                                      @JHerndon - Go to Google’s calendar web page and look for your calendar on the left hand side. When you hover over it with your mouse, you’ll see the 3 dots for the menu. Click on the dots and select “Settings and Sharing”.
                                      On the next page, scroll down to “integrate calendar”. Use those URLs (iCal format), no password required.
                                      • A
                                        arthurross
                                        I wish this worked with MMM-GoogleAnalytics
                                        • 6 / 6
