    MMM-Globe
    119 Posts 39 Posters 237.9k Views 40 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor @chris1971
      @chris1971
                  module: 'MMM-Globe',
                  position: 'middle_center',
                  style: 'europeDiscNat',
                  imageSize: 600,
                  ownImagePath:'https://eumetview.eumetsat.int/static-images/MSG/RGB/NATURALCOLOR/FULLRESOLUTION/IMAGESDisplay/VazIBqHF9k665',
                  updateInterval: 10*60*1000
      I hope this ok for you…
      • StoffbeuteluweS
        Stoffbeuteluwe Project Sponsor @Stoffbeuteluwe
        @Stoffbeuteluwe ist that ok?
          chris1971
          Great!!!
          It’s working with the link… where did you find it?
          Regards, Christoph
          • StoffbeuteluweS
            @chris1971 this is the link from the picture of the Earth on the eumesat webpage…
              chris1971
              yes - and now I still have the question if the picture will be updated automatically. With the old configuration (on the EUMETSAT server) I got a new picture every 15 minutes…
              • StoffbeuteluweS
                @chris1971 i hope so
                  chris1971
                  until now - no update… still the same picture since 2 hours…
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @chris1971
                    @chris1971
                    If you are using . . .
                    . . . then that address would need to update with a new picture for the module to retrieve and display it. If that address is a static picture then the module will only be able to display that.
                    • StoffbeuteluweS
                      Stoffbeuteluwe Project Sponsor @Mykle1
                      @Mykle1 perfekt thank you …
                        chris1971
                        I replaced the own image path in the css with “http://gif.keraunos.org/nuageseu.gif”.
                        The part of the css is looking now:
                        	imageSize: 500,
                        	ownImagePath:'http://gif.keraunos.org/nuageseu.gif',
                        	updateInterval: 1*60*1000 // ervery 2 minutes
                        It’s not a real globe, but a good animated gif for the weather forecast with clouds…
                        • saljokeS
                          saljoke
                          I replace the URL own image path with https://eumetview.eumetsat.int/static-images/latestImages/EUMETSAT_MSG_RGBNatColourEnhncd_LowResolution.jpg
                          There are different of quality but is the better I found
                            shgmongohh @saljoke
                            @saljoke
                            I also replaced the URL but the image doesn´t update.
                            Has anybody a solution, how to update the image automatically?
                                   ownImagePath:'https://eumetview.eumetsat.int/static-images/latestImages/EUMETSAT_MSG_RGBNatColourEnhncd_LowResolution.jpg',
                              sdetweil @shgmongohh
                              @shgmongohh said in MMM-Globe:
                              EUMETSAT_MSG_RGBNatColourEnhncd_LowResolution.jpg’
                                shgmongohh @sdetweil
                                I don´t think that it is static. Every hour the picture is updated with the same adress.
                                I thought that Globe updated the picture with the update intervall.
                                  jhoney Banned
                                  Cool and interesting! Im gonna try it out and see how it works.
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @shgmongohh
                                    Well, if that is the case then it should update the image in the module. I don’t use this module. Perhaps someone that does use it will chime in with there findings, or fixes.
                                    • FlatPepsiF
                                      FlatPepsi
                                      I see in the latest code that it is appending the date & time to avoid caching.
                                      I’ve added a number of console log messages to the code, and it looks like it’s never refreshing. Can anyone confirm that MMM-Globe really does refresh for them, after the initial page load?
                                      I’ve temporarily switched my mirror to MMM-iFrameReloaded, which does indeed refresh, but doesn’t scale the image to the size I need.
                                      • StoffbeuteluweS
                                        Stoffbeuteluwe Project Sponsor @FlatPepsi
                                        @FlatPepsi it is not working…
                                          dhruvgami1989
                                          B StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                                            bhepler Module Developer @dhruvgami1989
                                            @dhruvgami1989 - I wonder if the globe image is pushing the upper three regions higher? I have a couple things to try, but I don’t have a solution really.
                                            • Turn off the compliments temporarily and put the globe module in lower_third.
                                            • Reduce your globe image size and see if the weather forecast reappears
                                            • Move the globe to full_screen below, which should remove it from the shuffling that comes with the module positions.
                                            I hope one of these works for you.
                                            • 6 / 6
