    MMM-Globe
    119 Posts 39 Posters 232.4k Views 40 Watching
      shgmongohh @sdetweil
      I don´t think that it is static. Every hour the picture is updated with the same adress.
      I thought that Globe updated the picture with the update intervall.
        jhoney Banned
        Cool and interesting! Im gonna try it out and see how it works.
          Mykle1 Project Sponsor Module Developer @shgmongohh
          @shgmongohh said in MMM-Globe:
          Well, if that is the case then it should update the image in the module. I don’t use this module. Perhaps someone that does use it will chime in with there findings, or fixes.
          • FlatPepsiF Offline
            FlatPepsi
            I see in the latest code that it is appending the date & time to avoid caching.
            I’ve added a number of console log messages to the code, and it looks like it’s never refreshing. Can anyone confirm that MMM-Globe really does refresh for them, after the initial page load?
            I’ve temporarily switched my mirror to MMM-iFrameReloaded, which does indeed refresh, but doesn’t scale the image to the size I need.
            • StoffbeuteluweS Offline
              Stoffbeuteluwe Project Sponsor @FlatPepsi
              @FlatPepsi it is not working…
                dhruvgami1989
                B StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                  bhepler Module Developer @dhruvgami1989
                  @dhruvgami1989 - I wonder if the globe image is pushing the upper three regions higher? I have a couple things to try, but I don’t have a solution really.
                  • Turn off the compliments temporarily and put the globe module in lower_third.
                  • Reduce your globe image size and see if the weather forecast reappears
                  • Move the globe to full_screen below, which should remove it from the shuffling that comes with the module positions.
                  I hope one of these works for you.
                    Stoffbeuteluwe Project Sponsor @dhruvgami1989
                    @dhruvgami1989 my current weather appears after 10 minutes but I don’t know why.
                    Does your globe module update the Picture?
                    My globe module does not update.
                    D 1 Reply Last reply Reply Quote 2
                      dhruvgami1989 @Stoffbeuteluwe
                      @Stoffbeuteluwe Thanks for the tip. It came up exactly after 10 mins! Very weird. And no, the globe does not update
                        JHerndon
                        @dhruvgami1989 [unrelated] how do you use a private google calendar with a user/pass setup? I haven’t been able to find a tutorial for this.
                          bhepler Module Developer @JHerndon
                          @JHerndon - Go to Google’s calendar web page and look for your calendar on the left hand side. When you hover over it with your mouse, you’ll see the 3 dots for the menu. Click on the dots and select “Settings and Sharing”.
                          On the next page, scroll down to “integrate calendar”. Use those URLs (iCal format), no password required.
                            arthurross
                            I wish this worked with MMM-GoogleAnalytics
                            • 6 / 6
