    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 88.3k Views 28 Watching
      Smotx
      when I don’t activate this module, all my other modules work and display’s, when I activate this module, some modules are no longer displayed, such as: MMM-TPlink, MMM-CalendarExt, MMM-FreefoxMonitor.
      Anyone have an idea why?
      Thanks for help.
      • T Offline
        tbs86
        Every time i add this module and try to start the MM it tells me i have a syntax error and wont start any modules on my mirror.
        • evroomE Offline
          evroom
          Read this for learning purposes:
          https://forum.magicmirror.builders/topic/5399/how-to-check-your-config-for-errors-for-absolute-beginners
          If you post the config:check output and your MMM-GoogleMapsTraffic part inside config.js, I am sure someone can help you.
          Good luck.
          MagicMirror version: 2.35.0
          Test environment:
          MagicMirror version: 2.36.0-develop
          T 2 Replies Last reply Reply Quote 1
          • T Offline
            tbs86 @evroom
            @evroom thank you i will give this a shot when i get home and post my results
            • T Offline
              tbs86 @evroom
              @evroom ```here is my code
              		header: "US Holidays",
              					symbol: "calendar-check-o ",
              					url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
              		module: "compliments",
              		position: "lower_third"
              	var config = {
                      module: 'MMM-GoogleMapsTraffic',
                      position: 'bottom_left',
                          key: 'YOUR_KEY',
                          lat: 37.8262306,
                          lng: -122.2920096,
                          height: '300px',
                          width: '300px'
                          styledMapType: "transparent",
                          disableDefaultUI: true,
                          backgroundColor: 'hsla(0, 0%, 0%, 0)',
                          markers: [
                                  lat: 37.8262316,
                                  lng: -122.2920196,
                                  fillColor: '#9966ff'
              • evroomE Offline
                evroom
                Yes, the README tricked you a bit.
                Remove this:
                var config = {
                and the last 2 lines:
                Verify with:
                cd ~/MagicMirror; npm run config:check
                Test environment:
                T 1 Reply Last reply Reply Quote 1
                • T Offline
                  tbs86 @evroom
                  @evroom
                  did what you said and did the config check and this is what i got
                  Line 134 col 5 Unexpected ‘]’.
                  Line 134 col 5 Expected an identifier and instead saw ‘]’.
                  Line 134 col 6 Missing semicolon.
                  Line 134 col 5 Unrecoverable syntax error. (95% scanned).
                  pi@raspberrypi:~/MagicMirror $
                  • T Offline
                    tbs86
                    it says line 134 but the only thing on line 134 is a ]
                    here is my code leading up to 134
                        module: "MMM-EARTH",
                        position: "bottom_center",
                            mode: "Natural",
                            rotateInterval: 15000,
                            MaxWidth: "50%",
                            MaxHeight: "50%",
                    That is line 116 to 136 the end of my config
                      Mykle1 Project Sponsor Module Developer @tbs86
                      @tbs86
                      This is your current config entry
                      var config = {
                                  key: 'YOUR_KEY',
                                  lat: 37.8262306,
                                  lng: -122.2920096,
                                  height: '300px',
                                  width: '300px'
                                  markers: [
                                          lat: 37.8262316,
                                          lng: -122.2920196,
                      Make it look like this or copy and paste
                                  key: 'YOUR_KEY',
                                  lat: 37.8262306,
                                  lng: -122.2920096,
                                  height: '300px',
                                  width: '300px'
                                  markers: [
                                          lat: 37.8262316,
                                          lng: -122.2920196,
                      Props to @evroom
                      • T Offline
                        tbs86 @Mykle1
                        @mykle1 said in MMM-GoogleMapsTraffic:
                                key: 'YOUR_KEY',
                                lat: 37.8262306,
                                lng: -122.2920096,
                                height: '300px',
                                width: '300px'
                                markers: [
                                        lat: 37.8262316,
                                        lng: -122.2920196,
                        still getting a error
                          @tbs86
                          Sorry about that. I just checked it. Try this please. There was a comma missing after width: '300px', and no comma after the closing } Not your fault. The example in the readme is incorrect
                                  key: 'YOUR_KEY',
                                  lat: 37.8262306,
                                  lng: -122.2920096,
                                  height: '300px',
                                  width: '300px',
                                  markers: [
                                          lat: 37.8262316,
                                          lng: -122.2920196,
                          • T Offline
                            tbs86 @Mykle1
                            @mykle1
                            this worked thank you!!
                              @tbs86
                              You’re welcome, mate. :thumbsup:
                                rvanuden
                                it all seems to be working but googlemaps can not be loaded, i used a new key though
                                any ideas?
                                  rvanuden @rvanuden
                                  @rvanuden anyone?
                                    mcneilp @rvanuden
                                    @rvanuden I have the same problem. Did you find a solution?
                                      sdetweil
                                      there is a problem with the original module… I have a fixed version
                                      here https://github.com/sdetweil/MMM-GoogleMapsTraffic
                                      Do this
                                      cd ~/MagicMirror/modules
                                      mv  MMM-GoogleMapsTraffic  MMM-GoogleMapsTraffic.original
                                      git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic
                                      cd MMM-GoogleMapsTraffic
                                      npm install
                                      then restart the mirror app
                                      ChrisC 1 Reply Last reply Reply Quote 3
                                      • ChrisC Offline
                                        Chris @sdetweil
                                        @sdetweil said in MMM-GoogleMapsTraffic:
                                        Do this
                                        npm install
                                        Hello,
                                        Thank you so much,
                                        Regards,
                                          mcneilp
                                          I got it working. I did the above…plus I was using the wrong bit of text for my API key…and had to “setup billing” on my api account apparently to allow it to work.
                                            sdetweil @mcneilp
                                            @mcneilp thanks for the feedback… sad how many of the apis want to charge…
                                            • 3 / 5
