    Failed at the magicmirror@2.2.2 start script 'sh-run-start.sh'
    41 Posts 9 Posters 39.8k Views 8 Watching
    • L
      L_i_v_e @cruunnerr
      @cruunnerr after an auto install without sudo, made it work starting the installation of electron for the 2nd time in it’s folder. Now everything runs smooth if i give him commands but 1:
      -server only does not work, i can’t access it remotely
      -pm2 start does not work, the display goes all black but no module is loaded, it stays black. I tried with both my old config and the example config
      -maybe local launch does not work too? i have no idea since it’s really hard to connect a mouse and keyboard. If i use a VNC can i start it with npm start only?
      any idea?
      cruunnerrC 1 Reply Last reply Reply Quote 0
      • cruunnerrC
        cruunnerr @L_i_v_e
        @L_i_v_e said in Failed at the magicmirror@2.2.2 start script ‘sh-run-start.sh’:
        Yes.
        Since i started my project a few weeks/month ago i have had some trouble, too. But it was all about my inexperience. So at this point im out at all, sorry.
        Hope someone can help you.
        But if i said before: Reading the many tutorials and do it like it’s written there brought me to the goal.
        Only difference to you was, that i was using the early magic mirror versions.
        Maybe u should give it a last try with Version 2.1.3 and updating later or hoping that there are other guys who can help you. :(
        • C
          carltonb
          I too have the same problems. In another thread started a few days ago because I have the same issues.
          Started with Stretch, then went back to an old Jessie Lite version.
          I have done the automatic install, the manual install, as root and not as root.
          All fail at the same place. I currently have 5 MM running on PI3, then the update came and tried on one device when it crashed. I will not touch the others until this is resolved.
          If someone fixes this can they post the steps they used and a link to the image that they used as well.
          This is getting very frustrating. All my mirrors went together in a matter of an hour or so with no problems. Setting the modules and css is another thing though.
          Any help is very much appreciated.
          carltonb
          • cruunnerrC
            cruunnerr
            Because i am very interested why there are so much problems i will install a complete new Raspbian and MagicMirror. Let me try, i will report soon
            • L
              L_i_v_e
              Please let me know. If you make It work could you share It as an ISO ti flash? Would be so good
              • C
                carltonb
                I too am keeping abreast of this. I have had 5 installs that went so well that after the update, I can not get it installed.
                Are we the only ones having problems.
                Do the install directions need to be changed. Luckily I have backed up every sd card so I am safe, but need to figure out if I do anything to them now (besides the MM upgrade) will they crash.
                • cruunnerrC
                  cruunnerr
                  I think i figured out what went wrong ;)
                  i set up a new raspbian (Desktop Version) and could install the MagicMirro without any issues.
                  IMPORTANT:
                  while the installation of MagicMirror (automatic installer) u will see this:
                  Cloning MagicMirror Done!
                  Installing dependencies ...
                  npm WARN deprecated coffee-script@1.10.0: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                  npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                  npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                  > uws@0.14.5 install /home/pi/MagicMirror/node_modules/uws
                  > node-gyp rebuild > build_log.txt 2>&1 || exit 0
                  When u arrived this, it seems the installation is done. But wrong! just wait. it will take some time even if there is no cursor blinking.
                  Just wait and you will see some more installation steps:
                  Wait again:
                  wait again ^^ and u will be asked if u want to use pm2. say YES! :
                  Finally u will see this:
                  And after a few seconds the magic mirror will start automatically and u can enjoy :D
                  Edit:
                  so just to get sure, here are the quick steps i did:
                  1. loaded the newest raspbian stretch with desktop from here
                  2. copy to SD card with ApplePi-Baker
                  3. put an empty file named “ssh” on the boot directory to enable ssh
                  4. start the pi
                  5. via ssh sudo raspi-config
                    set up some configurations like Network-Name, Screen resolution, enabled VNC, expand filesystem etc.
                  6. reboot
                  7. sudo apt-get update ; sudo apt-get upgrade
                    this will take a while
                  8. sudo rpi-update
                    this will take a while, too
                  9. reboot
                  10. bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                  Then just wait! ;)
                  • C
                    carltonb @cruunnerr
                    @cruunnerr said in Failed at the magicmirror@2.2.2 start script ‘sh-run-start.sh’:
                    VNC
                    No NPM install or other necessary pi setup as listed on the site at Configuring the Raspberry Pi?
                    • cruunnerrC
                      cruunnerr
                      @carltonb said in Failed at the magicmirror@2.2.2 start script ‘sh-run-start.sh’:
                      Oh sorry, i enabled display rotate in the config. And to disable the screensaver i used sudo apt get install xscreensaver, then via VNC on the Desktop move to the upper left corner (the raspberry button) and go to Preference -> Screensaver and disable it.
                      Maybe use sudo apt-get install unclutter to hide mouse.
                      I just set it up to proof, if there are any issues ^^ So this was a quick install “guide”
                      But yes, there is no extra npm install or something like that necessary.
                      VNC can be enabled with raspi-config
                      edit:
                      oh, and keep in mind that u have to set pm2 to automatically start at reboot.
                      maybe after the first restart after installation finished there is no automatically startet MagicMirror.
                      https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                      L C 2 Replies Last reply Reply Quote 0
                      • L
                        L_i_v_e @cruunnerr
                        @cruunnerr lucky you… this is what i got
                        pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                        $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                        $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                        $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                        $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                        $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                        $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                        \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                                \______/
                        Updating packages ...
                        Trovato:1 https://deb.nodesource.com/node_9.x stretch InRelease
                        Scaricamento di:2 http://archive.raspberrypi.org/debian stretch InRelease [25,3 kB]
                        Trovato:3 http://mirrordirector.raspbian.org/raspbian stretch InRelease
                        Recuperati 25,3 kB in 11s (2.260 B/s)
                        Lettura elenco dei pacchetti... Fatto
                        Installing helper tools ...
                        Generazione albero delle dipendenze
                        Lettura informazioni sullo stato... Fatto
                        build-essential is already the newest version (12.3).
                        curl is already the newest version (7.52.1-5+deb9u3).
                        git is already the newest version (1:2.11.0-3+deb9u2).
                        unzip is already the newest version (6.0-21).
                        wget is already the newest version (1.18-5+deb9u1).
                        0 aggiornati, 0 installati, 0 da rimuovere e 0 non aggiornati.
                        Check current Node installation ...
                        Node currently installed. Checking version number.
                        Minimum Node version: v5.1.0
                        Installed Node version: v9.3.0
                        No Node.js upgrade necessary.
                        Cloning MagicMirror ...
                        Cloning into 'MagicMirror'...
                        remote: Counting objects: 9010, done.
                        remote: Total 9010 (delta 0), reused 0 (delta 0), pack-reused 9010
                        Ricezione degli oggetti: 100% (9010/9010), 11.45 MiB | 19.00 KiB/s, done.
                        Risoluzione dei delta: 100% (5098/5098), done.
                        > electron-chromedriver@1.7.1 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
                        > node ./download-chromedriver.js
                        > electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
                        > node install.js
                        /home/pi/MagicMirror/node_modules/electron/install.js:46
                          throw err
                        Error: read ECONNRESET
                            at _errnoException (util.js:999:13)
                            at TLSWrap.onread (net.js:629:25)
                        npm ERR! code ELIFECYCLE
                        npm ERR! errno 1
                        npm ERR! electron@1.4.15 postinstall: `node install.js`
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the electron@1.4.15 postinstall script.
                        npm ERR!     /home/pi/.npm/_logs/2018-01-05T20_56_42_584Z-debug.log
                        • cruunnerrC
                          cruunnerr
                          did you set it up freshly?
                          i can’t imagine that you haven’t crashed something before. Please try a new installation of raspbian
                          • C
                            carltonb @cruunnerr
                            @cruunnerr Tried your method on step 10 it took almost 90 minutes to finish!!!
                            I then went to the page on Auto Starting. Followed the directions. Rebooted.
                            MagicMirror screen flashed for about 3 seconds, then it went to the desktop for another 3 to 4 seconds then it stopped at the command line.
                            If I run the logs it tells me
                            [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                            /home/carltonb/.pm2/logs/mm-out-1.log last 15 lines:
                            1|mm       | > magicmirror@2.2.2 start /home/carltonb/MagicMirror
                            1|mm       | > sh run-start.sh
                            1|mm       |
                            1|mm       |
                            1|mm       |
                            1|mm       |
                            1|mm       |
                            1|mm       |
                            1|mm       |
                            /home/carltonb/.pm2/logs/mm-out-0.log last 15 lines:
                            0|mm       | > magicmirror@2.2.2 start /home/carltonb/MagicMirror
                            0|mm       | > sh run-start.sh
                            0|mm       |
                            0|mm       |
                            0|mm       |
                            0|mm       |
                            0|mm       |
                            0|mm       |
                            0|mm       |
                            /home/carltonb/.pm2/logs/mm-error-0.log last 15 lines:
                            0|mm       | npm ERR! npm  v3.10.10
                            0|mm       | npm ERR! path /home/carltonb/package.json
                            0|mm       | npm ERR! code ENOENT
                            0|mm       | npm ERR! errno -2
                            0|mm       | npm ERR! syscall open
                            0|mm       |
                            0|mm       | npm ERR! enoent ENOENT: no such file or directory, open '/home/carltonb/package.json'
                            0|mm       | npm ERR! enoent This is most likely not a problem with npm itself
                            0|mm       | npm ERR! enoent and is related to npm not being able to find a file.
                            0|mm       |
                            0|mm       | npm ERR! Please include the following file with any support request:
                            0|mm       | npm ERR!     /home/carltonb/npm-debug.log
                            0|mm       | /home/carltonb/mm.sh: line 1: cd: home/carltonb/MagicMirror: No such file or directory
                            /home/carltonb/.pm2/logs/mm-error-1.log last 15 lines:
                            1|mm       | npm ERR! npm  v3.10.10
                            1|mm       | npm ERR! path /home/carltonb/package.json
                            1|mm       | npm ERR! code ENOENT
                            1|mm       | npm ERR! errno -2
                            1|mm       | npm ERR! syscall open
                            1|mm       |
                            1|mm       | npm ERR! enoent ENOENT: no such file or directory, open '/home/carltonb/package.json'
                            1|mm       | npm ERR! enoent This is most likely not a problem with npm itself
                            1|mm       | npm ERR! enoent and is related to npm not being able to find a file.
                            1|mm       |
                            1|mm       | npm ERR! Please include the following file with any support request:
                            1|mm       | npm ERR!     /home/carltonb/npm-debug.log
                            1|mm       | /home/carltonb/mm.sh: line 1: cd: home/carltonb/MagicMirror: No such file or directory
                            0|mm       | npm
                            0|mm       |
                            0|mm       | ERR! Linux 4.9.59-v7+
                            0|mm       | npm
                            0|mm       |  ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                            0|mm       | npm ERR! node v6.12.3
                            0|mm       | npm ERR!
                            0|mm       |  npm  v3.10.10
                            0|mm       | npm
                            0|mm       |  ERR! enoent ENOENT: no such file or directory, open '/home/carltonb/package.json'
                            0|mm       | npm ERR!
                            0|mm       | enoent ENOENT: no such file or directory, open '/home/carltonb/package.json'
                            0|mm       | npm
                            0|mm       | ERR! enoent
                            1|mm       | npm
                            What step did I miss. It seems not to find the sh run-start.sh file. I am now so confused.
                            I will see how this sorts out over the weekend and will wait until Monday to try again.
                            • cruunnerrC
                              cruunnerr
                              When u say yes for using pm2 while installation, it will make a MagicMirror process by itself.
                              type pm2 status
                              If there is a task called “MagicMirror”, then try:
                              cd
                              pm2 stop MagicMirror
                              pm2 start mm.sh
                              pm2 save
                              edit: however i need to say, that 90 minutes is really really much!
                              The whole installation of the raspbian OS including the MagicMirror took me about one hour
                              and your mm.sh should look exactly like this:
                              cd MagicMirror  //here must be a wordwrap. so don't use one line
                              DISPLAY=:0 npm start
                              to create this file type in console:
                              cd
                              nano mm.sh
                              adding the lines above and save with “ctrl+x” and “y”
                              chmod +x mm.sh
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @carltonb
                                npm ERR! enoent ENOENT: no such file or directory, open ‘/home/carltonb/package.json’
                                Are you sure you are running npm start in the MagicMirror directory?
                                The error I quoted from your post usually indicates that you are issuing the npm start command from outside the MagicMirror directory. I can reproduce that error when NOT in the MagicMirror directory.
                                • C
                                  carltonb
                                  Back home and started again.
                                  Ran npm start in the /home/carltonb/MagicMirror directory here is the result
                                  carltonb@clock:~/MagicMirror $ npm start
                                  > sh run-start.sh
                                  npm ERR! Linux 4.9.75-v7+
                                  npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                                  npm ERR! magicmirror@2.2.2 start: `sh run-start.sh`
                                  npm ERR!
                                  npm ERR! Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
                                  npm ERR! If you do, this is most likely a problem with the magicmirror package,
                                  npm ERR! not with npm itself.
                                  npm ERR!     sh run-start.sh
                                  npm ERR!     npm bugs magicmirror
                                  npm ERR! Or if that isn't available, you can get their info via:
                                  npm ERR!     npm owner ls magicmirror
                                  npm ERR!     /home/carltonb/MagicMirror/npm-debug.log
                                  Followed cowboydude instructions for installing. This time it took about 10 minutes to install MM.
                                  What is my next step.
                                  Also thank all of you for taking the time to help a poor soul out.
                                  carltonb
                                  • C
                                    carltonb
                                    Just discovered that I have two installs of MM one in /home and one at /home/carltonb. Have to figure out why it is installed twice. When I did the bash for the install command I may not have specified directories. I will try again in a few hours.
                                    • cruunnerrC
                                      cruunnerr
                                      Well, what should i say…
                                      I installed the MMM-Podcast a few days ago and had some trouble with it, since it didn’t download newer videos…
                                      However, i tried a little bit to get it working (don’t know exactly what i did) and since there i thought it is running like it should.
                                      But wrong… it was only working, cause my MMM-watchdog module restarts the mirror automatically 1-3 times a day (Heartbeat timeout).
                                      Why am i telling this?
                                      Cause i got the exactly same message as you … o.0
                                      But different than you, my mirror is working at all except that it restarts some time.
                                      First i did what is showing in the message… i updated node and npm Version.
                                      node from 6.12.2 to 9.2.1
                                      ppm from 3.10.10 to 5.5.1
                                      I flushed pm2 logs and now i am waiting if the problem comes up again.
                                      Sorry that i can’t help you at all, but i am also trying to figure out what that could be.
                                      what OS are you running? Jesse or stretch? lite or desktop version?
                                      • C
                                        carltonb
                                        Running 2017-07-05-raspbian-jessie. Desktop image.
                                        Going to start again and see where I screwed up.
                                        • C
                                          carltonb
                                          Latest saga, though I am getting frustrated I am learning a lot about the process. I have looked at all the errors that are being given but do not know where to start.
                                          If I do a pm2 start mm.sh system gives me a report but nothing happens on my screen.
                                          npm-debug.log
                                          1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                                          2 info using npm@3.10.10
                                          3 info using node@v6.12.3
                                          5 info lifecycle magicmirror@2.2.2~prestart: magicmirror@2.2.2
                                          6 silly lifecycle magicmirror@2.2.2~prestart: no script for prestart, continuing
                                          7 info lifecycle magicmirror@2.2.2~start: magicmirror@2.2.2
                                          8 verbose lifecycle magicmirror@2.2.2~start: unsafe-perm in lifecycle true
                                          9 verbose lifecycle magicmirror@2.2.2~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/carltonb/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/$
                                          10 verbose lifecycle magicmirror@2.2.2~start: CWD: /home/carltonb/MagicMirror
                                          11 silly lifecycle magicmirror@2.2.2~start: Args: [ '-c', 'sh run-start.sh' ]
                                          12 silly lifecycle magicmirror@2.2.2~start: Returned: code: 1  signal: null
                                          13 info lifecycle magicmirror@2.2.2~start: Failed to exec start script
                                          14 verbose stack Error: magicmirror@2.2.2 start: `sh run-start.sh`
                                          14 verbose stack Exit status 1
                                          14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
                                          14 verbose stack     at emitTwo (events.js:106:13)
                                          14 verbose stack     at EventEmitter.emit (events.js:191:7)
                                          14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
                                          14 verbose stack     at ChildProcess.emit (events.js:191:7)
                                          14 verbose stack     at maybeClose (internal/child_process.js:920:16)
                                          14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
                                          15 verbose pkgid magicmirror@2.2.2
                                          16 verbose cwd /home/carltonb/MagicMirror
                                          17 error Linux 4.9.75-v7+
                                          18 error argv "/usr/bin/node" "/usr/bin/npm" "start"
                                          19 error node v6.12.3
                                          20 error npm  v3.10.10
                                          21 error code ELIFECYCLE
                                          22 error magicmirror@2.2.2 start: `sh run-start.sh`
                                          22 error Exit status 1
                                          23 error Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
                                          23 error Make sure you have the latest version of node.js and npm installed.
                                          23 error If you do, this is most likely a problem with the magicmirror package,
                                          23 error not with npm itself.
                                          23 error Tell the author that this fails on your system:
                                          23 error     sh run-start.sh
                                          23 error You can get information on how to open an issue for this project with:
                                          23 error     npm bugs magicmirror
                                          23 error Or if that isn't available, you can get their info via:
                                          23 error     npm owner ls magicmirror
                                          23 error There is likely additional logging output above.
                                          24 verbose exit [ 1, true ]
                                          pm2 logs
                                          0|mm       | No protocol specified
                                          0|mm       | npm
                                          0|mm       |
                                          0|mm       | ERR!
                                          0|mm       |  Linux 4.9.75-v7+
                                          0|mm       | npm
                                          0|mm       |
                                          0|mm       | ERR!
                                          0|mm       |  argv "/usr/bin/node" "/usr/bin/npm" "start"
                                          0|mm       | npm ERR! code ELIFECYCLE
                                          0|mm       | npm ERR! magicmirror@2.2.2 start: `sh run-start.sh`
                                          0|mm       | npm ERR! Exit status 1
                                          0|mm       | npm ERR!
                                          0|mm       | npm ERR! Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
                                          0|mm       | npm ERR! Make sure you have the latest version of node.js and npm installed.
                                          0|mm       | npm ERR! If you do, this is most likely a problem with the magicmirror package,
                                          0|mm       | npm ERR! not with npm itself.
                                          0|mm       | npm ERR! Tell the author that this fails on your system:
                                          0|mm       | npm ERR!     sh run-start.sh
                                          0|mm       | npm ERR!
                                          0|mm       |  You can get information on how to open an issue for this project with:
                                          0|mm       | npm
                                          0|mm       |
                                          0|mm       | ERR!
                                          0|mm       |      npm bugs magicmirror
                                          0|mm       | npm ERR! Or if that isn't available, you can get their info via:
                                          0|mm       | npm ERR!     npm owner ls magicmirror
                                          0|mm       | npm ERR! There is likely additional logging output above.
                                          0|mm       | npm ERR!
                                          0|mm       |      /home/carltonb/MagicMirror/npm-debug.log
                                          PM2        | App [mm] with id [0] and pid [5630], exited with code [1] via signal [SIGINT]
                                          PM2        | Starting execution sequence in -fork mode- for app name:mm id:0
                                          PM2        | App name:mm id:0 online
                                          npm start
                                          > sh run-start.sh
                                          npm ERR!
                                          • el97E
                                            el97
                                            I had this problem to but i fixed it with npm install electron in the MagicMirror directory.
                                            • 2 / 3
