    MMM-voice
    voice control
    329 Posts 55 Posters 974.1k Views 50 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @lucallmon
      @lucallmon can you check your access rights for user pi in MMM-voice, modules and a different module
      lucallmonL 1 Reply Last reply Reply Quote 0
      • lucallmonL Offline
        lucallmon @strawberry 3.141
        @strawberry-3.141 sorry, i’m pretty much a NOOB, how do I do that?
          lucallmon
          @strawberry-3-141 Ok, using sudo to install dependencies, I was able to get through 5/6, but now 6/6 failed:
          [STEP 5/6] Installing npm dependencies
          dependencies.sh: line 106: cd: /root/MagicMirror/modules/MMM-voice: No such file or directory
          npm WARN enoent ENOENT: no such file or directory, open '/root/pocketsphinx/package.json'
          npm WARN pocketsphinx No description
          npm WARN pocketsphinx No repository field.
          npm WARN pocketsphinx No README data
          npm WARN pocketsphinx No license field.
          [STEP 5/6] Installing npm dependencies | Done
          [STEP 6/6] Manipulating dependencies
          dependencies.sh: line 118: cd: /root/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous: No such file or directory
          sed: can't read index.js: No such file or directory
          [STEP 6/6] Manipulating dependencies | Failed
          thoughts?
            @lucallmon this will not work as it tries to look and do stuff in /root/... instead of /home/pi/...
              I’m curious if someone ever tried to find the easter egg in this module :thinking:
              Mykle1M A 2 Replies Last reply Reply Quote 1
                Mykle1 Project Sponsor Module Developer @strawberry 3.141
                @strawberry-3.141 said in MMM-voice:
                I tried the voice command, “Show me some boobs”, but I got nothing. :-)
                The same exact response I get from my wife.
                  abcdennis @strawberry 3.141
                  @strawberry-3.141 I found it, I just didn’t want to post any spoilers.
                    Mykle1 Project Sponsor Module Developer @abcdennis
                    @abcdennis said in MMM-voice:
                    How about a hint then? You can pm it if you don’t want to spoil it for others
                    strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 1
                      strawberry 3.141 Project Sponsor Module Developer @Mykle1
                      @Mykle1 A hint would be if you want to test it as a voice command you need to have mmm-tts installed as well or you try to reverse engineer it then you can start at the mmm-tts notification ;)
                        This is an impossibility. “shrug”
                        • 10
                        • 11
                        • 12
                        • 13
                        • 14
                        • 32
                        • 33
                        • 12 / 33
