    MMM-voice
    voice control
    329 Posts 55 Posters 978.8k Views 50 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @Guest
      @wjdw87 you can read your way through the installer and install the dependencies manually, only the first step is based on apt-get, maybe the rest is working on a Mac as well, then you can comment out step one and rerun the installer
      • P Offline
        plumcraft
        Hello,
        I’m trying the MMM-voice but no luck for now.
        I got “Error” on the Magic mirror and i have the following error in the debug.log :
        INFO: continuous.c(295): Specify ‘-infile <file.wav>’ to recognize from file or ‘-inmic yes’ to recognize from microphone.
        ERROR: “cmd_ln.c”, line 641: Duplicate argument name in arguments: -adcdev
        ERROR: “cmd_ln.c”, line 704: Failed to parse arguments list
        And got “12712712712712712712712711111111111111111111” in error.log
        I already tried couple of things :
        • reinstall the module by deleting the node_modules folder and rerun the dependencies.sh script.
        • upgrade everything with apt-get upgrade
        • Configure the usb microphone by creating .asound.rc file
        I’m using a standart usb microphone (http://www.banggood.com/fr/USB-Microphone-For-Raspberry-Pi-p-993726.html)
        I’ve found couple of differents versions how to setup an usb microphone on a RPI3 but no luck either to have a clear sound when i’m recording wav file to test it with following command :
        • arecord -D plughw:1,0 test_mic.wav
        Is there a excellent microphone for RPI3 ?
        Really looking forward to use this module.
        Thanks for your help
        • P Offline
          plumcraft
          With @strawberry-3-141 help, thanks again by the way, it’s working now :)
          If you got the same issue, here the solution :
          • delete the node_modules folder and then rerun the installer.
          • remove the words.json file on root module folder and restart the magic mirror.
            (It’s going to be regenerated when the module starts)
          That should be it.
          • W Offline
            witschi87
            Hey guys,
            i’ve installed the plugin but getting this error:
            pocketsphinx_continuous: error while loading shared libraries: libpocketsphinx.so.3: cannot open shared object file: No such file or directory
            Any suggestions?
            • bheplerB Offline
              bhepler Module Developer @witschi87
              @witschi87 Did you follow the installation instructions in the module’s readme.md file? Because it sure looks like you do not have PocketSphinx installed.
              • iMAGiCI Offline
                iMAGiC
                finally got it work… due to command behavior, all set, but don’t know how it works.
                @strawberry-3-141 is it possible that you could spend time to build a simple music player for MMM-voice module?
                all I need is random play mp3 in a folder, no need to select, just play and stop is OK via voice command.
                thanks in advance.
                Choice * Judgment * Values
                  strawberry 3.141 Project Sponsor Module Developer @iMAGiC
                  We could get Around the issue of @witschi87 but we dont know yet what the problem actually is. When he starts his mirror with DISPLAY=:0 nohup npm start & it works, with pm2 start mm not, but i have seen a couple using it with pm2 already
                  @iMAGiC sry I my Time is pretty Limited due to my Bachelor thesis, but i will have a look if i can adjust the Existent Music player to Voice commands easily
                  • G Offline
                    gismo2006
                    Some time ago @tyho help me a lot to to use voice commands in the module “Simple music Player” So I can use Start Stop Forward and back. I know in my case snoword hotword Detection was use but maybe it can help. If it was ok for @tyho I can post the code.
                    Maybe it will be an option for the first time, till @strawberry-3-141 have more time. :-)
                    Greets gismo
                      DirkS
                      Hi, in my case it does not stop blinking and only shows “initialisiere…”
                      I tried
                               microphone: 1,
                      and
                               microphone: '1',
                      but no effect.
                      iMAGiCI 1 Reply Last reply Reply Quote 0
                      • iMAGiCI Offline
                        iMAGiC @DirkS
                        @DirkS please say " magic mirror" at the first. when it flashing say “voice”, when it changes to Voice mode, you can say command.
                        • 6
                        • 7
                        • 8
                        • 32
                        • 33
                        • 6 / 33
