    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 222.3k Views 6 Watching
    • Cr4z33C
      Cr4z33 @evroom
      @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
      1. Perhaps stupid, but do not how to do that. Cannot open MM using the MM IP.
      Just run MM into DEV mode and in the right panel switch to the tab ‘Console’
      cd ~/MagicMirror/
      npm start dev
      • A
        AxLed Module Developer
        Can you send me following 5 xml files: …/web/about, …/web/getallservices, …/web/timerlist, …/web/servicelistplayable, … /web/epgnow by email ak10zeichen-xy@yahoo.de
        AxLED
        • evroomE
          evroom @AxLed
          @axled
          Forgot the port.
          I see this error:
          TypeError: undefined is not an object (evaluating 'json.e2servicelistrecursive.e2bouquet.e2servicelist.e2service')
          In line 229 of MMM-Dreambox.js:
          this.sender = json.e2servicelistrecursive.e2bouquet.e2servicelist.e2service;
          Mailed you the files.
          MagicMirror version: 2.37.0
          • Cr4z33C
            Cr4z33 @AxLed
            @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
            AxLED
            Me?
            • A
              @Cr4z33
              Yes.
              • Cr4z33C
                Cr4z33 @AxLed
                @axled OK gimme a minute and I send them. :winking_face:
                • evroomE
                  evroom
                  “You talking to me ?” (Robert de Niro - Taxi Driver).
                  I sent the files, just in case.
                  • A
                    AxLed Module Developer @evroom
                    I sent the files
                    @evroom
                    Thanks for the files, i checked them and found an Error in MMM-Dreambox.js
                    My “getallservices” xml only has one “bouquet”, so i checked only for one.
                    As your “getallservices” xml has three “bouquets” i changed the code.
                    If you do a git pull (master repository) it should work.
                    So far i decided only to show the services/stations/channels of the first bouquet only, (userbouquet.favourites.tv) in your case.
                    AxLED
                    • A
                      AxLed Module Developer @Cr4z33
                      @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                      @Cr4z33
                      Thanks for your files, one a fast view you also have more than one bouquet in “getallservices”, so my last fix should work for you also.
                      Try agit pull (master repository).
                      AxLED
                      • evroomE
                        evroom
                        @AxLed
                        The services list now is present.
                        Next step is to stream one.
                        • Cr4z33C
                          Cr4z33 @AxLed
                          @axled the situation now is like in the below screenshot and I still don’t know how I am supposed to stream a channel (if I don’t have to specify its url). :smiling_face_with_open_mouth_cold_sweat:
                          • evroomE
                            evroom
                            All actions:
                            http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT
                            http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-PREV
                            http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-PLAY
                            http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-STOP
                            Result in:
                            Cannot GET /remote
                            • A
                              @evroom
                              How do you plan to interact with your MM?
                              I have a rotary encoder. Buttons or touch is also fine.
                              For the beginning you can use MMM-Remote-Control to send notifications.
                              I have to complete my Readme, that the sample links only work with MMM-Remote-Control
                              So install MMM-Remote-Control, open an browser, modify the links matching to your environment and you should be able to select channels and stream them.
                              Important: Try with SD Channels first, as for HD channels the mpg2 codec is needed.
                              AxLED
                              evroomE 1 Reply Last reply Reply Quote 0
                              • evroomE
                                evroom @AxLed
                                @axled
                                I was about to ask about this.
                                Suppose it works, how will I use it in practise?
                                I have a Pi with a monitor connected hanging in the kitchen.
                                No fancy mirror like many, with speech and buttons and PIRs.
                                So, basically no interaction.
                                I plan on getting speech running, but I have other projects running at this moment (for instance Homematic IP and ioBroker).
                                I will try to install MMM-Remote-Control and see if that will work.
                                • A
                                  @Cr4z33
                                  I dont know if it makes sense, to use a favorite list of services/stations/channels that wont fit on the screen of MM, as the list is to long.
                                  Start streaming can be done by selecting one service/station/channel (by using yourmmip:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT for example) and than start streaming by (yourmmip:8080/remote?action=NOTIFICATION&notification=DB-PLAY).
                                  Do you have MMM-Remote-Control installed?
                                  Se my previous answer to evroom.
                                  AxLED
                                  Cr4z33C 2 Replies Last reply Reply Quote 0
                                  • Cr4z33C
                                    Cr4z33 @AxLed
                                    @axled oh now I understand.
                                    Thanks for the information.
                                    However I don’t have MMM-Remote-Control and I rather prefer to control everything by voice commands (MMM-AssistantMk2).
                                    Sorry, but then this module doesn’t suit my needs. :winking_face:
                                    • A
                                      @Cr4z33
                                      You should be able to send notifications by voice commands also.
                                      AxLED
                                      • A
                                        @evroom
                                        I have a PIR-Sensor (for turning screen on/off) and a rotary encoder connected (to the GPIO PINs of the Pi).
                                        In the bottom right corner you see my “first” module MMM-Navigate which interacts with the rotary encoder.
                                        So depending on the navigation menu i am able to:
                                        • swipe pages (i have four)
                                        • show Details to newsfeeds (opens website to the newsfeed)
                                        • adjust brightness
                                        • select dreambox channels
                                        • start/stop streaming dreambox channels
                                        • control the mirror (restart mm, shutdown, reboot)
                                        • and for the future: everything which can handle the MM notification system
                                        AxLED
                                        • evroomE
                                          evroom
                                          Okay, I have MMM-Remote-Control running and I can open the menu.
                                          Now using:
                                          I get this:
                                          {"status":"success"}
                                          Now I see a stream on my monitor !!
                                          With DB-SERVICE-NEXT and DB-SERVICE-PREV I can scroll through the services list
                                          Also gives
                                          But I cannot switch to another service with DB-PLAY.
                                          And I have a side effect that it takes 3 or 4 services on my Dreambox.
                                          I have the plugin InfoBarTunerState installed and I see that MM is trying to stream multiple services.
                                          At this moment I see one stream on my MM monitor, but my Dreambox tells me there are 2 MM streams present (on 2 different services).
                                          Here the OMXPlayer processes at this moment:
                                          pi@MagicPi:~/MagicMirror/modules $ ps -eaf | grep omxplayer | grep -v grep
                                          pi       28431 28259  0 18:06 ?        00:00:00 /bin/sh -c omxplayer  --win 320,180,1600,900  -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                          pi       28432 28431  0 18:06 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                          pi       28455 28432 10 18:06 ?        00:02:50 /usr/bin/omxplayer.bin --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                          pi       28522 28259  0 18:15 ?        00:00:00 /bin/sh -c omxplayer  --win 320,180,1600,900  -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
                                          pi       28523 28522  0 18:15 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
                                          pi       28546 28523  3 18:15 ?        00:00:31 /usr/bin/omxplayer.bin --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
                                          • evroomE
                                            evroom
                                            Btw, is there a possibility to have the start, next, prev and stop URL’s configured in MMM-Remote-Control ?
                                            • 6
                                            • 7
                                            • 8
                                            • 2 / 8
