    MMM-Globe
    119 Posts 39 Posters 222.8k Views 40 Watching
    • C Offline
      chris1971
      until now - no update… still the same picture since 2 hours…
        Mykle1 Project Sponsor Module Developer @chris1971
        @chris1971
        If you are using . . .
        ownImagePath:'https://eumetview.eumetsat.int/static-images/MSG/RGB/NATURALCOLOR/FULLRESOLUTION/IMAGESDisplay/VazIBqHF9k665',
                    updateInterval: 10*60*1000
        . . . then that address would need to update with a new picture for the module to retrieve and display it. If that address is a static picture then the module will only be able to display that.
        • StoffbeuteluweS Offline
          Stoffbeuteluwe Project Sponsor @Mykle1
          @Mykle1 perfekt thank you …
          • C Offline
            chris1971
            I replaced the own image path in the css with “http://gif.keraunos.org/nuageseu.gif”.
            The part of the css is looking now:
            module: 'MMM-Globe',
            position: 'middle_center',
            	style: 'europeDiscNat',
            	imageSize: 500,
            	ownImagePath:'http://gif.keraunos.org/nuageseu.gif',
            	updateInterval: 1*60*1000 // ervery 2 minutes
            It’s not a real globe, but a good animated gif for the weather forecast with clouds…
            • saljokeS Offline
              saljoke
              I replace the URL own image path with https://eumetview.eumetsat.int/static-images/latestImages/EUMETSAT_MSG_RGBNatColourEnhncd_LowResolution.jpg
              There are different of quality but is the better I found
                shgmongohh @saljoke
                @saljoke
                I also replaced the URL but the image doesn´t update.
                Has anybody a solution, how to update the image automatically?
                       ownImagePath:'https://eumetview.eumetsat.int/static-images/latestImages/EUMETSAT_MSG_RGBNatColourEnhncd_LowResolution.jpg',
                  sdetweil @shgmongohh
                  @shgmongohh said in MMM-Globe:
                  EUMETSAT_MSG_RGBNatColourEnhncd_LowResolution.jpg’
                    shgmongohh @sdetweil
                    I don´t think that it is static. Every hour the picture is updated with the same adress.
                    I thought that Globe updated the picture with the update intervall.
                      jhoney Banned
                      Cool and interesting! Im gonna try it out and see how it works.
                        Mykle1 Project Sponsor Module Developer @shgmongohh
                        Well, if that is the case then it should update the image in the module. I don’t use this module. Perhaps someone that does use it will chime in with there findings, or fixes.
                        • FlatPepsiF Offline
                          FlatPepsi
                          I see in the latest code that it is appending the date & time to avoid caching.
                          I’ve added a number of console log messages to the code, and it looks like it’s never refreshing. Can anyone confirm that MMM-Globe really does refresh for them, after the initial page load?
                          I’ve temporarily switched my mirror to MMM-iFrameReloaded, which does indeed refresh, but doesn’t scale the image to the size I need.
                            Stoffbeuteluwe Project Sponsor @FlatPepsi
                            @FlatPepsi it is not working…
                              dhruvgami1989
                              This post is deleted!
                              B StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                                bhepler Module Developer @dhruvgami1989
                                @dhruvgami1989 - I wonder if the globe image is pushing the upper three regions higher? I have a couple things to try, but I don’t have a solution really.
                                • Turn off the compliments temporarily and put the globe module in lower_third.
                                • Reduce your globe image size and see if the weather forecast reappears
                                • Move the globe to full_screen below, which should remove it from the shuffling that comes with the module positions.
                                I hope one of these works for you.
                                  Stoffbeuteluwe Project Sponsor @dhruvgami1989
                                  @dhruvgami1989 my current weather appears after 10 minutes but I don’t know why.
                                  Does your globe module update the Picture?
                                  My globe module does not update.
                                  D 1 Reply Last reply Reply Quote 2
                                    dhruvgami1989 @Stoffbeuteluwe
                                    @Stoffbeuteluwe Thanks for the tip. It came up exactly after 10 mins! Very weird. And no, the globe does not update
                                      JHerndon
                                      @dhruvgami1989 [unrelated] how do you use a private google calendar with a user/pass setup? I haven’t been able to find a tutorial for this.
                                        bhepler Module Developer @JHerndon
                                        @JHerndon - Go to Google’s calendar web page and look for your calendar on the left hand side. When you hover over it with your mouse, you’ll see the 3 dots for the menu. Click on the dots and select “Settings and Sharing”.
                                        On the next page, scroll down to “integrate calendar”. Use those URLs (iCal format), no password required.
                                          arthurross
                                          I wish this worked with MMM-GoogleAnalytics
                                          • 6
                                          • 6 / 6
