      Peter @cruunnerr
      @cruunnerr your english is good to understand.
      I think my MM is freezing indeed (see my other thread “something is wrong”).
      But I do not understand why NOAA gives yesterdays weather while freezing.
      If it gave only todays wheather I would understand.
      I suspect one of the other modules making my MM freeze.
      But which one …
      Peter
      • cruunnerrC
        cruunnerr
        if u use pm2, u should check pm2 logs and check the errors. Other way is to start MM with develop mode: npm start dev or with ssh: DISPLAY=:0 npm start dev
        Or start it with Firefox on your pc and use Firebug
          Peter @cruunnerr
          @cruunnerr , I am very sorry and it sounds stupid, but I have no idea how my MM starts.
          I had a lot problems to make its start automatically, but now it works.
          I cannot stop MM, only minimalise it with CRTL-M.
          SSH does not work (for some reason) VNC works well.
          Peter
            Peter
            After every update of MMM-NOAA the current weather is back in english again.
            Translation of the current weather is not in the Dutch translation file.
            Any idea how to fix this definitely?
            Peter
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @Peter
              @Peter said in MMM-NOAA - Another Weather Module:
              Isn’t the nl.json file Dutch translations? If not, you can help. How does that sound? :-)
              • Take any one of the translation files that you find in the tranaslations folder of the MMM-NOAA folder.
              • Make a copy of the file and rename the copy
              • Edit the copy . Don’t edit the left side which are the English words.
              • Edit the right side words so that they are the correct translations in Dutch for English words on the left side.
              • Save the file and submit it to the author
                Peter @Mykle1
                @Mykle1 thanks.
                I did something like that.
                This part is missing in the nl.json:
                "OVERCAST": "Overcast",
                "CLOUDY": "Cloudy",
                "RAIN": "Rain",
                "CLEAR": "Clear",
                "PARTLY_CLOUDY": "Partly Cloudy",
                So, I copied this from the en.json, pasted it in the nl.json and translated the right side, like this:
                "OVERCAST": "Grotendeels bewolkt",
                "CLOUDY": "Bewolkt",
                "RAIN": "Regen",
                "CLEAR": "Helder",
                "PARTLY_CLOUDY": "Gedeeltelijk bewolkt",
                After restarting MM it shows: Overcast …
                Strange about this: in the older version of NOAA the same part is missing in nl.json, but the translation is ok.
                So I presume the translation is somewhere else …
                Peter
                tbbearT 1 Reply Last reply Reply Quote 0
                • tbbearT
                  tbbear Module Developer @Peter
                  @Peter Hello Peter, i found the Problem since a few Versions of NOAA the translation comes directly from wunderground and during the last Change from @cowboysdude he made a small mistake. We will fix this soon.
                  Robert the Bear
                  P Mykle1M N 3 Replies Last reply Reply Quote 0
                    Peter @tbbear
                    @tbbear great!
                    Thanks!
                    Peter
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @tbbear
                      @tbbear said in MMM-NOAA - Another Weather Module:
                      Oh, this I did not know. Thanks for the info, Robert.
                      @Peter I am sure he will correct it soon enough
                      • N
                        Nilnik Project Sponsor @tbbear
                        @tbbear If you put lang: and your languagecode from Wunderground in MMM-NOAA:s config in my case SW for Sweden
                        it works.
                        • tbbearT
                          tbbear Module Developer @Nilnik
                          @Nilnik Hi, the problem is only in the latest version.
                          @ALL The problem is fixed , please do ur git pull in MMM-NOAA
                          Robert the Bear
                          • DesaydroneD
                            Desaydrone
                            I try to config this module, but i have some error when launching
                            0|mm       | App threw an error during load
                            0|mm       | Error: Cannot find module 'google-translate-api'
                            0|mm       |     at Module._resolveFilename (module.js:455:15)
                            0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                            0|mm       |     at Function.Module._load (module.js:403:25)
                            0|mm       |     at Module.require (module.js:483:17)
                            0|mm       |     at require (internal/module.js:20:19)
                            0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js:9:19)
                            0|mm       |     at Module._compile (module.js:556:32)
                            0|mm       |     at Object.Module._extensions..js (module.js:565:10)
                            0|mm       |     at Module.load (module.js:473:32)
                            0|mm       |     at tryModuleLoad (module.js:432:12)
                            0|mm       | Whoops! There was an uncaught exception...
                            0|mm       | { Error: Cannot find module 'google-translate-api'
                            0|mm       |     at tryModuleLoad (module.js:432:12) code: 'MODULE_NOT_FOUND' }
                            Di i made some mistake ? I never need google translate since now
                            DesaydroneD 1 Reply Last reply Reply Quote 0
                            • DesaydroneD
                              Desaydrone @Desaydrone
                              @Desaydrone said in MMM-NOAA - Another Weather Module:
                              Sorry i found my mistake, i forgot “npm install” :( Sorry
                                Johans
                                Sorry for these stupid questions.
                                1. How can I get the temperature with 1 or 2 decimals?
                                2. I want to get data from 2 different locations (Home & Holiday home abroud)
                                  Can I copy module & rename it MMM-NOAA2 or can I put 2 different API & PWS locations in?
                                • tbbearT
                                  tbbear Module Developer @Johans
                                  @Johans Hi Johans, to ask is never stupid. So to your questions:
                                  1. The module gets his data from Wunderground so it can only display what it gets.
                                  2. Yes, this should be possible and u said how it can be done. U can copy it to a new name and
                                    npm install their. Dont forget to add the renamed module in the config file
                                  Robert the Bear
                                    Johans @tbbear
                                    @tbbear thanks for the quick answer.
                                    I will copy & rename & add into config file.
                                    About temp with decimals, I installed also MMM-MyWeather which takes the data from wunderground (just to compare both weather modules) - in fact It uses same API & PWS as NOAA, but here i’m getting the temperature with 1 decimal. (not 7°, but 7.4°).
                                    Anyhow, no big deal, I can live with it. I just asked, maybe there was a setting for the temp decimals which wasn’t yet communicated or so.
                                    • tbbearT
                                      @Johans OK, so let me check what is possible
                                      (by the way u must have a very sensible skin to feel decimals … only joking)
                                      Robert the Bear
                                      • Y
                                        yawns Moderator @tbbear
                                        MMM-NOAA.js starting line 310. Math.round() is used which rounds up or down and eliminates decimals.
                                        Maybe you could add a config option to specify number of decimals?
                                        • cowboysdudeC
                                          Working on re-formatting this to have a smaller foot print…as I know space is a premium!
                                          Stay tuned…
                                          • cowboysdudeC
                                            Just a sneak peek…
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 34
                                            • 35
                                            • 14 / 35
