    690 Posts 77 Posters 3.3m Views 70 Watching
    • ChrisC
      Chris
      I tried to install this module but I can not make it work.
      instead of the module on the magic mirror screen, it says: “weather info”
      I attach to this post my config file:
      			module: 'MMM-NOAA',
      			position: 'top_right',
      				apiKey: "a3cXXXXX",    // https://www.wunderground.com/weather/api  select the middle plan...
      				useAir: true,             // set to false if you do not want to use Air Quality Index
      				airKey: "Z4pXXXXXXX",    // IF you want Air Quality Index
      				pws: "pws:I93SEVRA3",         // go here to find your pws: https://www.wunderground.com/wundermap
      				lat: "48.919XXX",        // need this for sunrise/sunset  if left blank none will show  -- find them here: http://www.latlong.net/
      				lon: "2.533XXX",       // need this for sunrise/sunset  if left blank none will showshowClock: true,           // Hides or shows clock
      				dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
      				format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
      				ampm: false,                // to show AM and PM on Sunrise/Sunset time
      				showGreet: false,          // deafult is false - to show greeting under clock and above date
      				name: "",                  // Your name
      				showWind: true,
      				showDate: false,
      				showForecast: true,         //show bottom 3 day forecast
      				flash: true,                 //Today in forecast flashes halo
      				showUV: true,               //show UV index
      				showBar: true,             // show Barometer
      				showHum: true,              //show Humidity level
      				position: 'top_right',       //whatever you have in above position must also be here
      				alert: true                //show weather alerts default is true
      By contrast, weather underground works properly so I think it does not come from the API key.
      Does anyone have an idea? Thank you
      • cowboysdudeC
        cowboysdude Module Developer @Chris
        @Chris start the mirror like this
        npm start dev
        in that window let me know what if any errors you’re getting :)
        • ChrisC
          Chris
          Thank you for your prompt response,
          here is what is indicated at startup:
          > magicmirror@2.2.1 start /home/pi/MagicMirror
          > sh run-start.sh "dev"
          Starting MagicMirror: v2.2.1
          Loading config ...
          Loading module helpers ...
          No helper found for module: calendar_monthly.
          Module helper loaded: MMM-MyCommute
          Module helper loaded: MMM-SoccerLiveScore
          Module helper loaded: MMM-soccer
          No helper found for module: MMM-Globe.
          Module helper loaded: MMM-Remote-Control
          Module helper loaded: mmm-suncalc
          Module helper loaded: MMM-NOAA
          No helper found for module: mmm-wu-moonphase.
          Module helper loaded: MMM-Tools
          No helper found for module: MMM-Snow.
          All module helpers loaded.
          Server started ...
          Connecting socket for: MMM-MyCommute
          ====================== Starting node_helper for module [MMM-MyCommute]
          Connecting socket for: MMM-SoccerLiveScore
          MMM-SoccerLiveScore helper started...
          Connecting socket for: MMM-soccer
          Starting module: MMM-soccer
          Connecting socket for: MMM-Remote-Control
          Starting node helper for: MMM-Remote-Control
          Connecting socket for: mmm-suncalc
          Starting node_helper for mmm-suncalc:
          Connecting socket for: MMM-NOAA
          Starting module: MMM-NOAA
          Connecting socket for: MMM-Tools
          Starting module: newsfeed
          Launching application.
          Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXX/basic.ics - Interval: 300000
          Get league table for url http://api.football-data.org/v1/competitions/450/leagueTable
          Create new news fetcher for url: http://www.leparisien.fr/actualites-a-la-une.rss.xml#xtor=RSS-1481423633 - Interval: 300000
          TypeError: Cannot read property 'observation_location' of undefined
              at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js:26:49)
              at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:186:22)
              at emitTwo (events.js:106:13)
              at Request.emit (events.js:191:7)
              at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1163:10)
              at emitOne (events.js:96:13)
              at Request.emit (events.js:188:7)
              at IncomingMessage. (/home/pi/MagicMirror/node_modules/request/request.js:1085:12)
              at IncomingMessage.g (events.js:286:16)
              at emitNone (events.js:91:20)
          Thanks for your help
          • cowboysdudeC
            @Chris said in MMM-NOAA - Another Weather Module:
            Cannot read property ‘observation_location’ of undefined
            Not seeing your location…
            ChrisC 1 Reply Last reply
            • ChrisC
              Chris @cowboysdude
              @cowboysdude said in MMM-NOAA - Another Weather Module:
              I corrected the pws value and it works. I made a mistake in the way of writing it.
              instead of
              pws: "I93SEVRA3",
              Sorry to have bothered you for so little
              Thank you very much for your help
              • cowboysdudeC
                @Chris Hahhahaahha it happens :) Glad you got it working!!! You didn’t bother me!!
                  Peter
                  First: this is a beautiful module, I like it very much!
                  But sometimes it does strange things: today is thursday and normally the module would show today, friday, saturday, etc.
                  But sometimes the module suddenly shows wednesday (yesterday) only.
                  After restarting (or from itself) the module is normal again.
                  Somebody any idea?
                  Peter
                  cruunnerrC 1 Reply Last reply
                  • cruunnerrC
                    cruunnerr @Peter
                    @Peter
                    It sounds like your whole MagicMirror instance freezes. But you can only see this at the NOAA module, because once the modules have loaded their informations they will show (without updated informations) their stuff.
                    So the other modules freezes, too but u can’t recognize it because u normally see no refreshing data. But on the NOAA module u expect a change of the shown data.
                    Sorry, my english is bad. Hope u could understand.
                    please check your log files and post the content
                    P 1 Reply Last reply
                      Peter @cruunnerr
                      @cruunnerr your english is good to understand.
                      I think my MM is freezing indeed (see my other thread “something is wrong”).
                      But I do not understand why NOAA gives yesterdays weather while freezing.
                      If it gave only todays wheather I would understand.
                      I suspect one of the other modules making my MM freeze.
                      But which one …
                      Peter
                      • cruunnerrC
                        cruunnerr
                        if u use pm2, u should check pm2 logs and check the errors. Other way is to start MM with develop mode: npm start dev or with ssh: DISPLAY=:0 npm start dev
                        Or start it with Firefox on your pc and use Firebug
                          Peter @cruunnerr
                          @cruunnerr , I am very sorry and it sounds stupid, but I have no idea how my MM starts.
                          I had a lot problems to make its start automatically, but now it works.
                          I cannot stop MM, only minimalise it with CRTL-M.
                          SSH does not work (for some reason) VNC works well.
                          Peter
                            Peter
                            After every update of MMM-NOAA the current weather is back in english again.
                            Translation of the current weather is not in the Dutch translation file.
                            Any idea how to fix this definitely?
                            Peter
                            Mykle1M 1 Reply Last reply
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @Peter
                              @Peter said in MMM-NOAA - Another Weather Module:
                              Isn’t the nl.json file Dutch translations? If not, you can help. How does that sound? :-)
                              • Take any one of the translation files that you find in the tranaslations folder of the MMM-NOAA folder.
                              • Make a copy of the file and rename the copy
                              • Edit the copy . Don’t edit the left side which are the English words.
                              • Edit the right side words so that they are the correct translations in Dutch for English words on the left side.
                              • Save the file and submit it to the author
                                Peter @Mykle1
                                @Mykle1 thanks.
                                I did something like that.
                                This part is missing in the nl.json:
                                "OVERCAST": "Overcast",
                                "CLOUDY": "Cloudy",
                                "RAIN": "Rain",
                                "CLEAR": "Clear",
                                "PARTLY_CLOUDY": "Partly Cloudy",
                                So, I copied this from the en.json, pasted it in the nl.json and translated the right side, like this:
                                "OVERCAST": "Grotendeels bewolkt",
                                "CLOUDY": "Bewolkt",
                                "RAIN": "Regen",
                                "CLEAR": "Helder",
                                "PARTLY_CLOUDY": "Gedeeltelijk bewolkt",
                                After restarting MM it shows: Overcast …
                                Strange about this: in the older version of NOAA the same part is missing in nl.json, but the translation is ok.
                                So I presume the translation is somewhere else …
                                Peter
                                tbbearT 1 Reply Last reply
                                • tbbearT
                                  tbbear Module Developer @Peter
                                  @Peter Hello Peter, i found the Problem since a few Versions of NOAA the translation comes directly from wunderground and during the last Change from @cowboysdude he made a small mistake. We will fix this soon.
                                  Robert the Bear
                                  P Mykle1M N 3 Replies Last reply
                                    Peter @tbbear
                                    @tbbear great!
                                    Thanks!
                                    Peter
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @tbbear
                                      @tbbear said in MMM-NOAA - Another Weather Module:
                                      Oh, this I did not know. Thanks for the info, Robert.
                                      @Peter I am sure he will correct it soon enough
                                      • N
                                        Nilnik Project Sponsor @tbbear
                                        @tbbear If you put lang: and your languagecode from Wunderground in MMM-NOAA:s config in my case SW for Sweden
                                        it works.
                                        • tbbearT
                                          tbbear Module Developer @Nilnik
                                          @Nilnik Hi, the problem is only in the latest version.
                                          @ALL The problem is fixed , please do ur git pull in MMM-NOAA
                                          Robert the Bear
                                          • DesaydroneD
                                            Desaydrone
                                            I try to config this module, but i have some error when launching
                                            0|mm       | App threw an error during load
                                            0|mm       | Error: Cannot find module 'google-translate-api'
                                            0|mm       |     at Module._resolveFilename (module.js:455:15)
                                            0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                            0|mm       |     at Function.Module._load (module.js:403:25)
                                            0|mm       |     at Module.require (module.js:483:17)
                                            0|mm       |     at require (internal/module.js:20:19)
                                            0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js:9:19)
                                            0|mm       |     at Module._compile (module.js:556:32)
                                            0|mm       |     at Object.Module._extensions..js (module.js:565:10)
                                            0|mm       |     at Module.load (module.js:473:32)
                                            0|mm       |     at tryModuleLoad (module.js:432:12)
                                            0|mm       | Whoops! There was an uncaught exception...
                                            0|mm       | { Error: Cannot find module 'google-translate-api'
                                            0|mm       |     at tryModuleLoad (module.js:432:12) code: 'MODULE_NOT_FOUND' }
                                            Di i made some mistake ? I never need google translate since now
                                            DesaydroneD 1 Reply Last reply
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 34
                                            • 35
                                            • 14 / 35
