    MMM-Gas
    56 Posts 13 Posters 43.8k Views 12 Watching
      mochman Module Developer @3d
      @3d Hmm, the code is supposed to use that variable as an integer. What kind of error were you getting when you had items: 10,?
      Edit: Guess it doesn’t matter. Math.min() still works using a string.
      3 1 Reply Last reply Reply Quote 1
      • 3 Offline
        3d @mochman
        @mochman It wasn’t loading the config.js. So I just stepped through line by line until if failed. Once if failed I put the 10 in quotations and it loaded.
        • justjim1220J Offline
          justjim1220 Module Developer
          Ok, so I deleted my current GAS module. and reinstalled it.
          I went to the website to check my zip code, which is good.
          I tried it with & without the quotes around the 10.
          Still not working for me… :slightly_frowning_face:
          Jim Hallock - 1995
            NVM!!!
            When in doubt, Reboot it out!!!
            :smiling_face_with_sunglasses:
            Jim Hallock - 1995
              rob73
              Is there any way to remove the Distance column? I live in a small town and dont really need the distances on the display. I hunted around the files a little bit and didnt see anything that I could maybe edit or delete that would remove it.
              Rob
                @rob73 I haven’t tried this to see how it looks, but you may just be able to comment out a few of the lines in MMM-Gas.js
                Try commenting out the last 2 lines of this code in the getDom() function.
                 var td5 = document.createElement("td");
                 td5.innerHTML = dist;
                 TDrow.appendChild(td5);
                 weatherTable.appendChild(TDrow);
                It should look like this when you’re done.
                //TDrow.appendChild(td5);
                //weatherTable.appendChild(TDrow);
                You should also comment out this part as well.
                var bjumpy = document.createElement("th");
                bjumpy.setAttribute("style", "text-align:center");
                bjumpy.classList.add("xsmall");
                bjumpy.innerHTML = "Distance";
                //xFCRow.appendChild(bjumpy);
                //weatherTable.appendChild(xFCRow);
                  rob73 @mochman
                  @mochman … Awesome… I followed your instructions and it worked! Thank you! I would have never figured that out on my own…
                  Thanks again!
                  Rob
                  • cowboysdudeC Offline
                    New config option to hide or show distance column.
                    example config:
                              disabled: false,
                              module: "MMM-Gas",
                                 zip: "14904",
                                 items: 10,
                                 typeGas: "",	//premium, mid-grade, diesel, or blank for regular
                                 sortBy: "price", 	//distance, price
                           distance: false //default is true, so using true just don't use distance in your config
                    DO a git pull in the MagicMirror/modules/MMM-Gas dir to update!
                    AND a HUGE Thanks to @mochman for all the help!!!
                      @cowboysdude
                      Thanks. I really like this module alot. Very nice options and I love the mouse overs. Fantastic work! :thumbsup:
                        rob73
                        Awesome!
                        • richland007R Offline
                          richland007
                          Is this still working?? It was working flawlessly for me before but i turned the MM off for like 3 months when i was doing some work around the house and when i turned it back on i do not see anything on my list of gas stations.
                          It just says updated at this time and date but nothing listed.
                          I did a git pull thinking that something might have been updated in those 3 months but nothing changed.
                          Anyone else experiencing difficulties ???
                          D
                          Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
                            Mykle1 Project Sponsor Module Developer @richland007
                            @richland007 said in MMM-Gas:
                            I just did a git pull on my current installation and everything seems to be working just fine.
                            Have you made any modifications? Are there any errors being reported in the terminal or dev console?
                              cowboysdude Module Developer @richland007
                              @richland007 Do a git pull as things did change and I updated it a month ago or so.
                                richland007
                                I did a git pull and than an npm install insde the module but still no luck only updated on today’s date and time.
                                No list of gas stations nothing just that.
                                Do we have to change anything in the module settings on the config.js file for the update??
                                Denis
                                  @richland007
                                  This should be your config entry. Have you tried another zip code? See if this one works.
                                              disabled: false,
                                              module: "MMM-Gas",
                                              position: "top center",
                                                  zip: "10306"
                                  richland007R 1 Reply Last reply Reply Quote 1
                                    richland007 @Mykle1
                                    @Mykle1 Nothing solved it but a complete rm -rf and than a reinstall now it works fine
                                    thank you
                                    D
                                      @richland007
                                      :thumbsup:
                                        DDE12
                                        How do you change the size of the font in the module?
                                          sdetweil @DDE12
                                          @DDE12 custom.css, like always
                                          look to see if it has a css file which would tell u the class names used,
                                          then use custom.css to override those settings
                                            DDE12 @sdetweil
                                            @sdetweil There are two of them: MMM-Gas.css and MMM-Gas1.css. MMM-Gas did not seem to do anything and I was able to make some changes with MMM-Gas1 but not to the font size. Both css files have:
                                            .MMM-Gas .xxsmall{
                                            	font-size: 12px;
                                            Changing it has no effect.
                                            In dev mode, changing
                                            .xsmall {
                                                font-size: var(--font-size-xsmall);
                                            from main.css does change the font size. I assume that this will affect any other module that uses the xsmall font.
                                            Is there a way through my css to set the font size for this module only?
                                            • 2 / 3
