    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 895.3k Views 74 Watching
      jackoliver361 @j.e.f.f
      @j-e-f-f 0_1548845698182_problem.JPG it still does it even though alexa is in bottom center, here is my config file.
        robiv8
        Thanks for the tip. Now it working in German.
        • N Offline
          nobita @lavolp3
          @lavolp3 ,after install DarkSkyForecast only “Loading…” display and use " npm start dev"
          Error happen like this
          someone help me please,how to solve it
          Mykle1M S 2 Replies Last reply Reply Quote 0
            Mykle1 Project Sponsor Module Developer @nobita
            @nobita
            You have to cd into the MagicMirror directory first, then run npm start dev
            pop@HPEu:~$ cd MagicMirror/
            pop@HPEu:~/MagicMirror$ npm start dev
              robiv8
              You must be in your MagicMirror folder!
              and then type: npm start dev
              Oh! Sorry @Mykle1
              Did not see that you have already answered.
                Mykle1 Project Sponsor Module Developer @robiv8
                @robiv8
                No worries. I like your answer so much that I’m upvoting it! :thumbsup:
                  sdetweil @nobita
                  • N Offline
                    nobita @Mykle1
                    @mykle1 Thank so much,Beacuse I’m Beginner and my mistake
                      @nobita
                      You’re welcome. We all make mistakes. We were all beginners. Can’t we all just get along? :-)
                      Peace!
                      • N Offline
                        nobita @Mykle1
                        @mykle1 Ask again after install MMM-DarkSkyForecast nothing happen only Loading
                        How can I first step to find error?
                        Thanks for everyone to help me again
                          Post your config entry for that module using a code block so others can have a look at it for you
                          N 2 Replies Last reply Reply Quote 0
                          • H Offline
                            HanSolo
                            it is pssible to add the sunrise and sunset in the DarkSky-Modul.
                            I need a huge of help, becuase i have no idea to insert the sunrise and sunset.
                            Any ideas or a little tutorial for me?
                            Thanks @all.
                            • lavolp3L Offline
                              lavolp3 Module Developer @HanSolo
                              @hansolo MMM-forecast-io has sunset and sunrise time integrated and both take data from the same source.
                              So yes, it’s possible. The data is there. But I’m out. I’m unfortunately currently sitting on other projects.
                              How to troubleshoot modules
                              MMM-soccer v2, MMM-AVStock
                              R E 2 Replies Last reply Reply Quote 1
                                robiv8 @lavolp3
                                @lavolp3
                                this little peace of code where be very nice ;-)
                                • N Offline
                                  nobita @Mykle1
                                  • N Offline
                                    nobita
                                    • N Offline
                                      nobita @Mykle1
                                      @mykle1 ,What happen after install DarkSkyForecast (as config below)
                                      My config
                                      module: “MMM-DarkSkyForecast”,
                                      header: “Weather”,
                                      position: “middle_center”,
                                      classes: “default everyone”,
                                      disabled: false,
                                      apikey: “xxxxxxxxxxxxxxxxxxxx”,
                                      latitude: “13.756331”,
                                      longitude: “100.501762”,
                                      iconset: “4c”,
                                      concise: false,
                                      forecastLayout: “table”
                                      Thanks for your help
                                        codenamegopher @michael5r
                                          motdog
                                            j.e.f.f Project Sponsor Module Developer @nobita
                                            @nobita said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                            My config
                                            header: “Weather”,
                                            disabled: false,
                                            iconset: “4c”,
                                            concise: false,
                                            I just tested with your config, and it works for me. All I did was changed the curly quotes to straight quotes and put in my api key, but otherwise i left everything else the same. Do you see anything errors in the either Electron’s console or MagicMirror’s server-side error log?
                                            • 16
                                            • 17
                                            • 6 / 17
