    MMM-SystemStats (cpu temp/load, fre ram ...)
    74 Posts 36 Posters 81.3k Views 35 Watching
    • B
      BenRoe Module Developer
      [card:benroe/MMM-SystemStats]
      It’s testet with a Raspberry Pi.
      MMM-MMM-SystemStats
      ToDO:
      • icons
      • sd-card available space
      • better indication for the system load
      If you found an issue, please report it here.
      If you like the module, give it a star on Github.
      T M BKeyportB N 4 Replies Last reply Reply Quote 3
      • T
        tgriffo @BenRoe
        G’day @BenRoe
        when using your module (Raspberry Pi powered) I get the below message and nothing appears to work. If I comment out the MMM-SystemStats module config on config/config.js the other modules work again.
        (node:2247) DeprecationWarning: sys is deprecated. Use util instead.
        Any clues?
        Cheers,
        Tiago
        • B
          I also have this message, but everything works. It’s only a hint.
          Are there some other messages?
          • T
            tgriffo
            I shall try again (currently travelling for work) later this week and report back with more details…
            • K
              KirAsh4 Moderator
              Deprecation is not the same as a hint. That message is a warning to let you know that while it may work today, it may not in the near future because sys is being deprecated and ultimately phased out (and removed) in favor of util. It would make sense to write code for the packages that will continue to work, and not for things that will be deprecated.
              • M
                Mar @BenRoe
                @BenRoe the classes config item is the exact same name used by the MMM-ProfileSwitcher plugin unfortunately.
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @KirAsh4
                  @KirAsh4 said in MMM-SystemStats (cpu temp/load, fre ram ...):
                  I also get that warning message but it works and nothing seems to be wrong or unstable. I like having the stats to keep an eye on how things are running, then I hide it with MMM-Remote-Control until the next time I want to check.
                  So, do you recommend NOT using it? Is there any “danger” in using it?
                  • B
                    @Mykle1 it is not “danger”. Next days a update is coming.
                    • B
                      The update v1.1 is out. Thx to Bruce17 for the pull request.
                      Update instructions
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @BenRoe
                        @BenRoe said in MMM-SystemStats (cpu temp/load, fre ram ...):
                        I followed the update instructions. It seems to be working fine and the “DeprecationWarning: sys is deprecated. Use util instead.” is no longer being reported. Nice!
                        • T
                          toldenburger
                          Any way I can make this module alight to the left?
                          DocVooDooD 1 Reply Last reply Reply Quote 0
                          • DocVooDooD
                            DocVooDoo @toldenburger
                            @toldenburger
                            position: ‘top_left’, // This can be any of the regions.
                            or
                            position: ‘bottom_left’, // This can be any of the regions.
                            T 1 Reply Last reply Reply Quote 1
                            • T
                              toldenburger @DocVooDoo
                              @DocVooDoo Ah sorry I wasn’t clear enough:
                              I don’t mean the position of the module, but the alignment of the actual text. It seems to be centered by default and I can’t find a css in the module.
                              DocVooDooD strawberry 3.141S 2 Replies Last reply Reply Quote 0
                              • DocVooDooD
                                @toldenburger Oh, I would like to know.
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @toldenburger
                                  @toldenburger put that in custom.css
                                  .MMM-SystemStats table td {
                                    text-align: left !important;
                                  Mykle1M 1 Reply Last reply Reply Quote 3
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @strawberry 3.141
                                    @strawberry-3.141 said in MMM-SystemStats (cpu temp/load, fre ram ...):
                                    Oh, I’m so glad you got here first, before I tried to help him. :wink:
                                    • B
                                      @toldenburger @DocVooDoo the v1.2 is out
                                      • add pull request #2 (automatic translate loding label)
                                      • new config item (align the labels)
                                      • Sandy2503S
                                        Sandy2503
                                        How Can I change the Fontsize of the Modul ?
                                        Sandy2503
                                        AgilesChromsA 1 Reply Last reply Reply Quote 0
                                        • M
                                          McSorley
                                          Perfect along with MMM-RemoteControl to hide and enable it when I am testing.
                                          • AgilesChromsA
                                            AgilesChroms @Sandy2503
                                            @Sandy2503
                                            one solution
                                            wrapper.className = this.config.classes ? this.config.classes : “bold small bright”;
                                            • 1 / 4
