    MMM-voice
    voice control
    329 Posts 55 Posters 955.6k Views 50 Watching
    • E Offline
      ealfaror @strawberry 3.141
      @strawberry-3.141 Thanks! I’ve changed it and it works!
      I hope I’ll remember it when the module updates. :)
        Allred
        I am not sure what I am missing/doing wrong. I have gotten everything installed and working after several attempts. I enabled debugging so I could see what it was capturing. Magic mirror activated microphone just fine. I could see the text below it that it was recognising, but if I said hide, or hide modules. It won’t hide any modules.
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Allred
          @Allred sounds like you didn’t enter the voice mode first
          MAGIC MIRROR VOICE HIDE MODULES will activate the microphone, switch to voice mode and performs the task hide modules.
          For every following command in the voice mode you have to say
          MAGIC MIRROR SHOW MODULES or when the microphone is already active just SHOW MODULES until you switch into another mode, then you would have to say voice again
          Mykle1M 1 Reply Last reply Reply Quote -1
            Mykle1 Project Sponsor Module Developer @strawberry 3.141
            @strawberry-3.141
            What do I need?
            Do I need a specific microphone?
            If I get a webcam with a built in microphone, will that work?
            If the webcam microphone will work, which webcam do you recommend?
            I just want to have everything I need before I try anything, thanks.
              strawberry 3.141 Project Sponsor Module Developer @Mykle1
              @Mykle1 i’m just using a usb microphone, never tried a buil in mic of a webcam because i don’t have one
                @strawberry-3.141 said in MMM-voice:
                i’m just using a usb microphone, never tried a buil in mic of a webcam because i don’t have one.
                I actually got it working on a laptop with Ubuntu so I am now trying it on the Pi 3 with MMM-voice and a Logitech USB microphone. It loads with “Initializing” next to the microphone and for a second it shows “Ready, choose a mode.” but then it changes to Error. I tried to make it the default in Audio Device Settings on the Pi3 but it keeps going back to "bcm2835 (ALSA mixer) (Default). It won’t keep the “AK5370 (Alsa mixer)” as default.
                 0 [ALSA           ]: bcm2835 - bcm2835 ALSA
                                      bcm2835 ALSA
                 1 [AK5370         ]: USB-Audio - AK5370
                                      AKM AK5370 at usb-3f980000.usb-1.2, full speed
                I’m going to bed!
                  @Mykle1 just set the config to microphone: 1
                    I guess I should have mentioned that I already have that setting. I was tired. Does this mean that microphone is not compatible?
                      @Mykle1 if you want i can have a look via remote desktop session
                      Mykle1M 2 Replies Last reply Reply Quote 0
                        That would be great but I have to run to work for a few hours. I’ll be back in about 4 hours. So, perhaps later if you are available. I’d appreciate that.
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 32
                        • 33
                        • 8 / 33
