    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 894.6k Views 74 Watching
      btorres79 @j.e.f.f
      @j-e-f-f Thanks for the info. I will give it a go. Thanks for creating an awesome module.
        robiv8
        and how can I doit this for german?
        and when you say “…Set units: “us” in your config.”
        where comes this in the config?
        please take a look at my sample config
          module: "MMM-DarkSkyForecast",
          header: "Weather",
          classes: "default everyone",
          disabled: false,
            apikey: "SUPER SECRET!!!",
            latitude: "51.506130",
            longitude: "-0.090270",
            iconset: "4c",
            concise: false,
            forecastLayout: "table",
            units: "auto", < - - #### is this so right for german?
            language: "de" < - - #### is this so right for german?
          j.e.f.f Project Sponsor Module Developer @robiv8
          @robiv8 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
            header: "Weather",
            disabled: false,
              iconset: "4c",
              concise: false,
          My module doesn’t support the auto parameter for units, even though it’s valid for calling Dark Sky’s API directly. My thinking was that it’s ambiguous as to what you might get, and everyone will know exactly which units of measure they want. So you need to specify one of the four explicit options for units:
          si : metric units. (temp in Celcius, wind measured in m/s)
          ca: same as si but wind measured in km/h
          uk2: same as si, but wind measured in mph
          us : imperial units. (temp in Farhenheit, wind in mph)
          If you specify anything else or omit the units config, the module defaults to ca. (Oh Canada!)
          As for the language config, this is independent of units. This will determine editorial content that the API returns such as the weather summary, and eventually when I get around to adding it, weather alerts. If you leave it blank, it will use the language config for MagicMirror, so if you’ve already got MM configured for German, then you don’t need to set the language parameter to get this content in German. The parameter is there in case for some reason you want a language other than what you have MM configured for, or maybe MM doesn’t support your preferred language, but Dark Sky does, for example x-pig-latin for Pig Latin. (Seriously… try it!)
          • swvalentiS Offline
            swvalenti Project Sponsor
            When I installed this module it did not import current region settings etc based on pi software install as I had to change them all in the config. I just thought I was an idiot and did something wrong when installing module and didn’t want to look like a fool posting an issue. HA!
              robiv8
              Thanks for the explanation.
              Without extra entries in the config, the weather and the text is in German.
              But the time on US like 7pm 1pm and so on …
              How can I change that and where?
                j.e.f.f Project Sponsor Module Developer @nobita
                @nobita said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                from your info " …this module requires MagicMirror version 2.2.0 or later…"
                so How can I know my version of Magic Mirror?
                Thanks so much
                Two ways you can tell… When you start MM with npm start you’ll see the version number of MagicMirror. Otherwise, just try running the module. If you get weird gibberish on the screen that looks like default non-specific module content then you need to upgrade. Otherwise, if you see weather content, then you’re fine.
                If you’ve installed Magic Mirror somewhat recently, then likely your version is adequate.
                  In the README file there are a few config options you’ll be interested in:
                  label_maximum
                  label_high
                  label_low
                  label_timeFormat
                  label_days
                  label_ordinals
                  These can be used to customize text to your exact liking.
                  Read about all of the config parameters here:
                  https://github.com/jclarke0000/MMM-DarkSkyForecast/blob/master/README.md
                    jackoliver361 @j.e.f.f
                    @j-e-f-f 0_1548845698182_problem.JPG it still does it even though alexa is in bottom center, here is my config file.
                      robiv8
                      Thanks for the tip. Now it working in German.
                      • N Offline
                        nobita @lavolp3
                        @lavolp3 ,after install DarkSkyForecast only “Loading…” display and use " npm start dev"
                        Error happen like this
                        someone help me please,how to solve it
                        Mykle1M S 2 Replies Last reply Reply Quote 0
                          Mykle1 Project Sponsor Module Developer @nobita
                          @nobita
                          You have to cd into the MagicMirror directory first, then run npm start dev
                          pop@HPEu:~$ cd MagicMirror/
                          pop@HPEu:~/MagicMirror$ npm start dev
                            robiv8
                            You must be in your MagicMirror folder!
                            and then type: npm start dev
                            Oh! Sorry @Mykle1
                            Did not see that you have already answered.
                              Mykle1 Project Sponsor Module Developer @robiv8
                              @robiv8
                              No worries. I like your answer so much that I’m upvoting it! :thumbsup:
                                sdetweil @nobita
                                This post is deleted!
                                • N Offline
                                  nobita @Mykle1
                                  @mykle1 Thank so much,Beacuse I’m Beginner and my mistake
                                    @nobita
                                    You’re welcome. We all make mistakes. We were all beginners. Can’t we all just get along? :-)
                                    Peace!
                                    • N Offline
                                      nobita @Mykle1
                                      @mykle1 Ask again after install MMM-DarkSkyForecast nothing happen only Loading
                                      How can I first step to find error?
                                      Thanks for everyone to help me again
                                        Post your config entry for that module using a code block so others can have a look at it for you
                                        N 2 Replies Last reply Reply Quote 0
                                        • H Offline
                                          HanSolo
                                          Hello,
                                          it is pssible to add the sunrise and sunset in the DarkSky-Modul.
                                          I need a huge of help, becuase i have no idea to insert the sunrise and sunset.
                                          Any ideas or a little tutorial for me?
                                          Thanks @all.
                                          • lavolp3L Offline
                                            lavolp3 Module Developer @HanSolo
                                            @hansolo MMM-forecast-io has sunset and sunrise time integrated and both take data from the same source.
                                            So yes, it’s possible. The data is there. But I’m out. I’m unfortunately currently sitting on other projects.
                                            How to troubleshoot modules
                                            MMM-soccer v2, MMM-AVStock
                                            R E 2 Replies Last reply Reply Quote 1
                                            • 6
                                            • 7
                                            • 8
                                            • 16
                                            • 17
                                            • 6 / 17
