    MMM-Globe
    119 Posts 39 Posters 233.9k Views 40 Watching
    • V Offline
      Vauxdvihl
      Sorry for the question
      But is there a view for europe available / configurable?
      • Z Offline
        zzaidi148 @LukeCodewalker
        @LukeCodewalker Really nice module its just that I cant see it on my magicmirror. Config boots up and everything looks fine its just that the image doesn’t come up. I tried putting it center and middle center but didnt work. Any ideas?
          dasb00ter
          So if u read the read me it basically tells you how to set the region!
          Also help!
          This module loads and displays but the globe does NOT update for me. I’ve left the update config settings to default. If I restart the mirror the image does update. Also if somebody knows of a north American image that can be used please let me know although I would be just happy to get an updating globe.
          Thanks for your time
          @Vauxdvihl said in MMM-Globe:
          • P Offline
            Pimagical @iMAGiC
            @iMAGiC to many requests will cause a ip block, keep it default
            dasbooterD 1 Reply Last reply Reply Quote 0
            • dasbooterD Offline
              dasbooter @Pimagical
              @Pimagical said in MMM-Globe:
              I’ve tried default config for time and then after a few days tried an extended time in the config. Same issue. I can post my config but I’m confident it does not exceed the time limitations of the sources. I’m wondering if it is a caching issue like in the iframe reloaded module that wouldn’t refresh until I added some lines that I found in this forum
              • P Offline
                Pimagical @dasbooter
                @dasbooter Your using a highres image source of 14mb maybe there are other limitations for this source, maybe you could try a lower resolution source?
                My experience with resize above 800pixels for example 900 pixels the MMM-Globe script picks the highress source but my MagicMirror keeps black, could be to much for the raspberry pi 3 or a bug in the MMM-Globe…
                • Andrius okA Offline
                  Andrius ok
                  How to make globe a little bit lower than center? Thanks!
                    Andrius ok @GinSeng
                    Hello @GinSeng maybe you know how to make a little bit lower than ‘middle_center’ ?
                    Thanks!
                    Mykle1M strawberry 3.141S 2 Replies Last reply Reply Quote 0
                      Mykle1 Project Sponsor Module Developer @Andrius ok
                      @Andrius-ok said in MMM-Globe:
                      bottom_center
                      Or you could try some css on it I suppose
                      • strawberry 3.141S Offline
                        strawberry 3.141 Project Sponsor Module Developer @Andrius ok
                        @Andrius-ok the region under middle_center is called lower_third https://forum.magicmirror.builders/topic/286/regions
                        Andrius okA 1 Reply Last reply Reply Quote 0
                          Thanks yes I tried smaller images. Still same problem for me. Looking at the module yes at 800 pixels or above it does call for a different image source. A hi res one . Really good thought tho. Thanks. Oh well pretty soon I’ll give it to my girlfriend for christmas. Then it will be out of site and outta mind. I’ll keep checking back. Or maybe just a clean install one day ```
                          //your code here
                            dasbooter @dasbooter
                                                    module: 'MMM-Globe',
                                                    position: 'upper_third',
                                                    style: 'geoColor',
                                                    imageSize: 350,
                                                    updateInterval: 15*60*1000
                              Andrius ok @strawberry 3.141
                              Thanks @strawberry-3.141 I’am appreciated!
                              • P Offline
                                Peter
                                I have the same problem as Matt about a year ago.
                                The globe works perfect but after some time I see only some lines.
                                Some time later it is fine again.
                                Any help?
                                Peter
                                This is Matts picture a year ago:
                                G iMAGiCI dasbooterD P 4 Replies Last reply Reply Quote 0
                                • G Offline
                                  gshimself @Peter
                                  @Peter I use to have that, and that is when my SD card got full. do a
                                  df -h
                                  and see if the storage is full or not
                                  • iMAGiCI Offline
                                    iMAGiC @Peter
                                    @Peter I found this issue when I attache this module into MM, due to the link is not very stable, and it stop working sometime. you could try other link (e.g. full), it will work.
                                    Choice * Judgment * Values
                                    • P Offline
                                      Peter @gshimself
                                      @gshimself , there is still 8.5 G left on the 16G card.
                                      Peter
                                      • P Offline
                                        Peter @iMAGiC
                                        @iMAGiC , what do you mean with " full"?
                                        Is there a good link to the side of the earth with Europe?
                                        Peter
                                        iMAGiCI 1 Reply Last reply Reply Quote 0
                                        • iMAGiCI Offline
                                          iMAGiC @Peter
                                          @Peter
                                          sorry, I meaning use hi-res url instead of it.
                                          for example:
                                          this.imageUrls = {
                                          			'geoColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_true_color.jpg',
                                          @Peter said in MMM-Globe:
                                          Peter
                                            dasbooter @Peter
                                            @Peter I agree with the post about changing the link. I had the same problem then I changed sources and have had no issue.
                                            • 6
                                            • 4 / 6
