    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 918.2k Views 74 Watching
      robiv8
      You must be in your MagicMirror folder!
      and then type: npm start dev
      Oh! Sorry @Mykle1
      Did not see that you have already answered.
        Mykle1 Project Sponsor Module Developer @robiv8
        @robiv8
        No worries. I like your answer so much that I’m upvoting it! :thumbsup:
          sdetweil @nobita
          • N Offline
            nobita @Mykle1
            @mykle1 Thank so much,Beacuse I’m Beginner and my mistake
              Mykle1 Project Sponsor Module Developer @nobita
              @nobita
              You’re welcome. We all make mistakes. We were all beginners. Can’t we all just get along? :-)
              Peace!
              • N Offline
                nobita @Mykle1
                @mykle1 Ask again after install MMM-DarkSkyForecast nothing happen only Loading
                How can I first step to find error?
                Thanks for everyone to help me again
                  Post your config entry for that module using a code block so others can have a look at it for you
                  N 2 Replies Last reply Reply Quote 0
                  • H Offline
                    HanSolo
                    it is pssible to add the sunrise and sunset in the DarkSky-Modul.
                    I need a huge of help, becuase i have no idea to insert the sunrise and sunset.
                    Any ideas or a little tutorial for me?
                    Thanks @all.
                    • lavolp3L Offline
                      lavolp3 Module Developer @HanSolo
                      @hansolo MMM-forecast-io has sunset and sunrise time integrated and both take data from the same source.
                      So yes, it’s possible. The data is there. But I’m out. I’m unfortunately currently sitting on other projects.
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                      R E 2 Replies Last reply Reply Quote 1
                        robiv8 @lavolp3
                        @lavolp3
                        this little peace of code where be very nice ;-)
                        • N Offline
                          nobita @Mykle1
                          • N Offline
                            nobita
                            • N Offline
                              nobita @Mykle1
                              @mykle1 ,What happen after install DarkSkyForecast (as config below)
                              only “Loading…” display
                              My config
                              module: “MMM-DarkSkyForecast”,
                              header: “Weather”,
                              position: “middle_center”,
                              classes: “default everyone”,
                              disabled: false,
                              apikey: “xxxxxxxxxxxxxxxxxxxx”,
                              latitude: “13.756331”,
                              longitude: “100.501762”,
                              iconset: “4c”,
                              concise: false,
                              forecastLayout: “table”
                              Thanks for your help
                                codenamegopher @michael5r
                                  motdog
                                    j.e.f.f Project Sponsor Module Developer @nobita
                                    @nobita said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                    My config
                                    header: “Weather”,
                                    disabled: false,
                                    iconset: “4c”,
                                    concise: false,
                                    I just tested with your config, and it works for me. All I did was changed the curly quotes to straight quotes and put in my api key, but otherwise i left everything else the same. Do you see anything errors in the either Electron’s console or MagicMirror’s server-side error log?
                                    • N Offline
                                      nobita @j.e.f.f
                                      @j-e-f-f Thanks for your hint ,I think I will new install MagicMirror and Darkskyforecast again
                                      • lavolp3L Offline
                                        @nobita @j-e-f-f did not advise that. With the current information, I don’t think that helps.
                                        You need to check the error logs as jeff hinted at by one of the ways described here in the forum several times.
                                        One quick way is running the mirror with the command
                                        npm start dev
                                        and looking if there is an error message showing up on your console or in the browser if you access the mirror from another computer.
                                          motdog
                                          dumb question I’m sure but when placing this in the config.js I should get rid of the default weather program, right?
                                          S J 2 Replies Last reply Reply Quote 0
                                            sdetweil @motdog
                                            @motdog you could leave them both in for a little while to check that they both say the same thing!
                                            • 16
                                            • 17
                                            • 7 / 17
