    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 915.5k Views 74 Watching
    • H Offline
      HanSolo
      it is pssible to add the sunrise and sunset in the DarkSky-Modul.
      I need a huge of help, becuase i have no idea to insert the sunrise and sunset.
      Any ideas or a little tutorial for me?
      Thanks @all.
      • lavolp3L Offline
        lavolp3 Module Developer @HanSolo
        @hansolo MMM-forecast-io has sunset and sunrise time integrated and both take data from the same source.
        So yes, it’s possible. The data is there. But I’m out. I’m unfortunately currently sitting on other projects.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        R E 2 Replies Last reply Reply Quote 1
          robiv8 @lavolp3
          @lavolp3
          this little peace of code where be very nice ;-)
          • N Offline
            nobita @Mykle1
            • N Offline
              nobita
              • N Offline
                nobita @Mykle1
                @mykle1 ,What happen after install DarkSkyForecast (as config below)
                only “Loading…” display
                My config
                module: “MMM-DarkSkyForecast”,
                header: “Weather”,
                position: “middle_center”,
                classes: “default everyone”,
                disabled: false,
                apikey: “xxxxxxxxxxxxxxxxxxxx”,
                latitude: “13.756331”,
                longitude: “100.501762”,
                iconset: “4c”,
                concise: false,
                forecastLayout: “table”
                Thanks for your help
                  codenamegopher @michael5r
                    motdog
                      j.e.f.f Project Sponsor Module Developer @nobita
                      @nobita said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                      My config
                      header: “Weather”,
                      disabled: false,
                      iconset: “4c”,
                      concise: false,
                      I just tested with your config, and it works for me. All I did was changed the curly quotes to straight quotes and put in my api key, but otherwise i left everything else the same. Do you see anything errors in the either Electron’s console or MagicMirror’s server-side error log?
                      • N Offline
                        nobita @j.e.f.f
                        @j-e-f-f Thanks for your hint ,I think I will new install MagicMirror and Darkskyforecast again
                        • lavolp3L Offline
                          @nobita @j-e-f-f did not advise that. With the current information, I don’t think that helps.
                          You need to check the error logs as jeff hinted at by one of the ways described here in the forum several times.
                          One quick way is running the mirror with the command
                          npm start dev
                          and looking if there is an error message showing up on your console or in the browser if you access the mirror from another computer.
                            motdog
                            dumb question I’m sure but when placing this in the config.js I should get rid of the default weather program, right?
                            S J 2 Replies Last reply Reply Quote 0
                              sdetweil @motdog
                              @motdog you could leave them both in for a little while to check that they both say the same thing!
                                motdog @sdetweil
                                @sdetweil I tried that & could not get dark sky to show up at all. That’s why I am confused
                                  sdetweil @motdog
                                  @motdog me too… can u open the developers console, and see if there are any errors?
                                  either ctrl-shift-i (letter i) while MM is running,
                                  or
                                  npm start dev
                                  to start with the dev console…
                                  then select the console tab in the right handle white pane. scroll up to find any errors… in red text usually
                                    j.e.f.f Project Sponsor Module Developer @motdog
                                    @motdog said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                    You don’t have to. It will just mean you’ll have weather information from two sources. But one wouldn’t (shouldn’t ?) conflict with the other.
                                      motdog @j.e.f.f
                                      @j-e-f-f thats what I thought. Im just having all sorts of weird issues with both weather modules. I may just need to redo them
                                        motdog
                                        Ive got it up but when I change “table” to “tiled” I get a config error when I restart.
                                        When I add units: us I get an error. Ugh.
                                        This works```
                                        //your cod {
                                        header: “Weather”,
                                        position: “top_right”,
                                        disabled: false,
                                        apikey: “*********”,
                                        latitude: “38.751389”,
                                        longitude: “-90.565948”,
                                        iconset: “4c”,
                                        concise: true,
                                        },e here
                                        this doesnt
                                        header: “Weather”,
                                        disabled: false,
                                        apikey: “*******”,
                                        iconset: “4c”,
                                        concise: true,
                                        units: us,
                                          sdetweil @motdog
                                          @motdog always hide your apikey values. with ***
                                            motdog @sdetweil
                                            @sdetweil thanks. I finally got this module the way I wanted. On to the next one!
                                            • 16
                                            • 17
                                            • 7 / 17
