    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 933.2k Views 74 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @robiv8
      @robiv8
      No worries. I like your answer so much that I’m upvoting it! :thumbsup:
        sdetweil @nobita
        • N
          nobita @Mykle1
          @mykle1 Thank so much,Beacuse I’m Beginner and my mistake
          Mykle1M 1 Reply Last reply
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @nobita
            @nobita
            You’re welcome. We all make mistakes. We were all beginners. Can’t we all just get along? :-)
            Peace!
            N 1 Reply Last reply
            • N
              nobita @Mykle1
              @mykle1 Ask again after install MMM-DarkSkyForecast nothing happen only Loading
              How can I first step to find error?
              Thanks for everyone to help me again
              • Mykle1M
                Post your config entry for that module using a code block so others can have a look at it for you
                N 2 Replies Last reply
                • H
                  HanSolo
                  it is pssible to add the sunrise and sunset in the DarkSky-Modul.
                  I need a huge of help, becuase i have no idea to insert the sunrise and sunset.
                  Any ideas or a little tutorial for me?
                  Thanks @all.
                  lavolp3L 1 Reply Last reply
                  • lavolp3L
                    lavolp3 Module Developer @HanSolo
                    @hansolo MMM-forecast-io has sunset and sunrise time integrated and both take data from the same source.
                    So yes, it’s possible. The data is there. But I’m out. I’m unfortunately currently sitting on other projects.
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                    R E 2 Replies Last reply
                      robiv8 @lavolp3
                      @lavolp3
                      this little peace of code where be very nice ;-)
                      • N
                        nobita @Mykle1
                        • N
                          nobita
                          • N
                            nobita @Mykle1
                            @mykle1 ,What happen after install DarkSkyForecast (as config below)
                            only “Loading…” display
                            My config
                            module: “MMM-DarkSkyForecast”,
                            header: “Weather”,
                            position: “middle_center”,
                            classes: “default everyone”,
                            disabled: false,
                            apikey: “xxxxxxxxxxxxxxxxxxxx”,
                            latitude: “13.756331”,
                            longitude: “100.501762”,
                            iconset: “4c”,
                            concise: false,
                            forecastLayout: “table”
                            Thanks for your help
                            J 1 Reply Last reply
                              codenamegopher @michael5r
                                motdog
                                  j.e.f.f Project Sponsor Module Developer @nobita
                                  @nobita said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                  My config
                                  header: “Weather”,
                                  disabled: false,
                                  iconset: “4c”,
                                  concise: false,
                                  I just tested with your config, and it works for me. All I did was changed the curly quotes to straight quotes and put in my api key, but otherwise i left everything else the same. Do you see anything errors in the either Electron’s console or MagicMirror’s server-side error log?
                                  • N
                                    nobita @j.e.f.f
                                    @j-e-f-f Thanks for your hint ,I think I will new install MagicMirror and Darkskyforecast again
                                    • lavolp3L
                                      @nobita @j-e-f-f did not advise that. With the current information, I don’t think that helps.
                                      You need to check the error logs as jeff hinted at by one of the ways described here in the forum several times.
                                      One quick way is running the mirror with the command
                                      npm start dev
                                      and looking if there is an error message showing up on your console or in the browser if you access the mirror from another computer.
                                        motdog
                                        dumb question I’m sure but when placing this in the config.js I should get rid of the default weather program, right?
                                        S J 2 Replies Last reply
                                          sdetweil @motdog
                                          @motdog you could leave them both in for a little while to check that they both say the same thing!
                                            motdog @sdetweil
                                            @sdetweil I tried that & could not get dark sky to show up at all. That’s why I am confused
                                            • 16
                                            • 17
                                            • 7 / 17
