    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 942.6k Views 74 Watching
    • Mykle1M
      Post your config entry for that module using a code block so others can have a look at it for you
      N 2 Replies Last reply
      • H
        HanSolo
        it is pssible to add the sunrise and sunset in the DarkSky-Modul.
        I need a huge of help, becuase i have no idea to insert the sunrise and sunset.
        Any ideas or a little tutorial for me?
        Thanks @all.
        lavolp3L 1 Reply Last reply
        • lavolp3L
          lavolp3 Module Developer @HanSolo
          @hansolo MMM-forecast-io has sunset and sunrise time integrated and both take data from the same source.
          So yes, it’s possible. The data is there. But I’m out. I’m unfortunately currently sitting on other projects.
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          R E 2 Replies Last reply
            robiv8 @lavolp3
            @lavolp3
            this little peace of code where be very nice ;-)
            • N
              nobita @Mykle1
              • N
                nobita
                • N
                  nobita @Mykle1
                  @mykle1 ,What happen after install DarkSkyForecast (as config below)
                  only “Loading…” display
                  My config
                  module: “MMM-DarkSkyForecast”,
                  header: “Weather”,
                  position: “middle_center”,
                  classes: “default everyone”,
                  disabled: false,
                  apikey: “xxxxxxxxxxxxxxxxxxxx”,
                  latitude: “13.756331”,
                  longitude: “100.501762”,
                  iconset: “4c”,
                  concise: false,
                  forecastLayout: “table”
                  Thanks for your help
                  J 1 Reply Last reply
                    codenamegopher @michael5r
                      motdog
                        j.e.f.f Project Sponsor Module Developer @nobita
                        @nobita said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                        My config
                        header: “Weather”,
                        disabled: false,
                        iconset: “4c”,
                        concise: false,
                        I just tested with your config, and it works for me. All I did was changed the curly quotes to straight quotes and put in my api key, but otherwise i left everything else the same. Do you see anything errors in the either Electron’s console or MagicMirror’s server-side error log?
                        N 1 Reply Last reply
                        • N
                          nobita @j.e.f.f
                          @j-e-f-f Thanks for your hint ,I think I will new install MagicMirror and Darkskyforecast again
                          • lavolp3L
                            @nobita @j-e-f-f did not advise that. With the current information, I don’t think that helps.
                            You need to check the error logs as jeff hinted at by one of the ways described here in the forum several times.
                            One quick way is running the mirror with the command
                            npm start dev
                            and looking if there is an error message showing up on your console or in the browser if you access the mirror from another computer.
                              motdog
                              dumb question I’m sure but when placing this in the config.js I should get rid of the default weather program, right?
                              S J 2 Replies Last reply
                                sdetweil @motdog
                                @motdog you could leave them both in for a little while to check that they both say the same thing!
                                M 1 Reply Last reply
                                  motdog @sdetweil
                                  @sdetweil I tried that & could not get dark sky to show up at all. That’s why I am confused
                                    sdetweil @motdog
                                    @motdog me too… can u open the developers console, and see if there are any errors?
                                    either ctrl-shift-i (letter i) while MM is running,
                                    or
                                    npm start dev
                                    to start with the dev console…
                                    then select the console tab in the right handle white pane. scroll up to find any errors… in red text usually
                                      j.e.f.f Project Sponsor Module Developer @motdog
                                      @motdog said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                      You don’t have to. It will just mean you’ll have weather information from two sources. But one wouldn’t (shouldn’t ?) conflict with the other.
                                        motdog @j.e.f.f
                                        @j-e-f-f thats what I thought. Im just having all sorts of weird issues with both weather modules. I may just need to redo them
                                          motdog
                                          Ive got it up but when I change “table” to “tiled” I get a config error when I restart.
                                          When I add units: us I get an error. Ugh.
                                          This works```
                                          //your cod {
                                          header: “Weather”,
                                          position: “top_right”,
                                          disabled: false,
                                          apikey: “*********”,
                                          latitude: “38.751389”,
                                          longitude: “-90.565948”,
                                          iconset: “4c”,
                                          concise: true,
                                          },e here
                                          this doesnt
                                          header: “Weather”,
                                          disabled: false,
                                          apikey: “*******”,
                                          iconset: “4c”,
                                          concise: true,
                                          units: us,
                                            sdetweil @motdog
                                            @motdog always hide your apikey values. with ***
                                            • 16
                                            • 17
                                            • 7 / 17
