    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 891.4k Views 74 Watching
      robiv8 @lavolp3
      @lavolp3
      this little peace of code where be very nice ;-)
      • N Offline
        nobita @Mykle1
        This post is deleted!
        • N Offline
          nobita
          • N Offline
            nobita @Mykle1
            @mykle1 ,What happen after install DarkSkyForecast (as config below)
            only “Loading…” display
            My config
            module: “MMM-DarkSkyForecast”,
            header: “Weather”,
            position: “middle_center”,
            classes: “default everyone”,
            disabled: false,
            apikey: “xxxxxxxxxxxxxxxxxxxx”,
            latitude: “13.756331”,
            longitude: “100.501762”,
            iconset: “4c”,
            concise: false,
            forecastLayout: “table”
            Thanks for your help
            • C Offline
              codenamegopher @michael5r
                motdog
                  j.e.f.f Project Sponsor Module Developer @nobita
                  @nobita said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                  My config
                  header: “Weather”,
                  disabled: false,
                  iconset: “4c”,
                  concise: false,
                  I just tested with your config, and it works for me. All I did was changed the curly quotes to straight quotes and put in my api key, but otherwise i left everything else the same. Do you see anything errors in the either Electron’s console or MagicMirror’s server-side error log?
                  • N Offline
                    nobita @j.e.f.f
                    @j-e-f-f Thanks for your hint ,I think I will new install MagicMirror and Darkskyforecast again
                    • lavolp3L Offline
                      lavolp3 Module Developer
                      @nobita @j-e-f-f did not advise that. With the current information, I don’t think that helps.
                      You need to check the error logs as jeff hinted at by one of the ways described here in the forum several times.
                      One quick way is running the mirror with the command
                      npm start dev
                      and looking if there is an error message showing up on your console or in the browser if you access the mirror from another computer.
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                        motdog
                        dumb question I’m sure but when placing this in the config.js I should get rid of the default weather program, right?
                        S J 2 Replies Last reply Reply Quote 0
                          sdetweil @motdog
                          @motdog you could leave them both in for a little while to check that they both say the same thing!
                            motdog @sdetweil
                            @sdetweil I tried that & could not get dark sky to show up at all. That’s why I am confused
                              sdetweil @motdog
                              @motdog me too… can u open the developers console, and see if there are any errors?
                              either ctrl-shift-i (letter i) while MM is running,
                              or
                              npm start dev
                              to start with the dev console…
                              then select the console tab in the right handle white pane. scroll up to find any errors… in red text usually
                                j.e.f.f Project Sponsor Module Developer @motdog
                                @motdog said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                You don’t have to. It will just mean you’ll have weather information from two sources. But one wouldn’t (shouldn’t ?) conflict with the other.
                                  motdog @j.e.f.f
                                  @j-e-f-f thats what I thought. Im just having all sorts of weird issues with both weather modules. I may just need to redo them
                                    motdog
                                    Ive got it up but when I change “table” to “tiled” I get a config error when I restart.
                                    When I add units: us I get an error. Ugh.
                                    This works```
                                    //your cod {
                                    header: “Weather”,
                                    position: “top_right”,
                                    disabled: false,
                                    apikey: “*********”,
                                    latitude: “38.751389”,
                                    longitude: “-90.565948”,
                                    iconset: “4c”,
                                    concise: true,
                                    },e here
                                    this doesnt
                                    header: “Weather”,
                                    disabled: false,
                                    apikey: “*******”,
                                    iconset: “4c”,
                                    concise: true,
                                    units: us,
                                      sdetweil @motdog
                                      @motdog always hide your apikey values. with ***
                                        motdog @sdetweil
                                        @sdetweil thanks. I finally got this module the way I wanted. On to the next one!
                                          @motdog You have specified units without quotes. need to write it like this:
                                          units: "us",
                                          Cr4z33C M 2 Replies Last reply Reply Quote 0
                                          • Cr4z33C Offline
                                            Cr4z33 @j.e.f.f
                                            @j-e-f-f I don’t know why, but when I use your module after a while MM becomes all dark although modules keep working (ie. MMM-AssistantMk2).
                                            There’s no specific timing for the issue to appear (it can be after 1 hour or after 15 mins, etc.).
                                            Modules won’t appear again until I restart MM.
                                            This is my current module config:
                                            			module: "MMM-DarkSkyForecast",
                                            			header: "Meteo",
                                            			classes: "default everyone",
                                            			disabled: false,
                                            					apikey: "***",
                                            					latitude: "***",
                                            					longitude: "***",
                                            					language: "it",
                                            					forecastHeaderText: "***",
                                            					label_timeFormat: "hh:mm",
                                            					iconset: "4c",
                                            					concise: false,
                                            					showSummary: false,
                                            					forecastLayout: "table"
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 16
                                            • 17
                                            • 7 / 17
