MMM-voice
@strawberry-3.141 said in MMM-voice:
@AxLed https://cmusphinx.github.io/wiki/faq/#q-which-languages-are-supported
@strawberrxyy 3.141
I tried to change the language to german / german voice recognition with some informations from here:
https://mycroft.ai/documentation/language-support/german/
but my skills a not good enough to get it working.3 more questions:
Is there a command for commandline to test Pocketsphinx and its components, so maybe i can find out where i went in the wrong direction.Do i need for changing the language model only have to download certain files and bring them in the right structure or do i have to compile something afterwards?
Where could i change the path to other language models in MMM-voice, i only found links to the .lm an .dic file but not to the
.../model/en-us/structure.AxLED
pocketsphinx_continuous- You need to look for instructions where you downloaded those files
- you can specify the language model with the option
-hmmin the node dependenciepocketsphinx-continuous-node
In case you get it running in German can you share it?
could really use this as well :)Max
@maxbachmann even if he’s able to get german running are the commands and supported modules only working with english, to make this possible there is a big effort necessary, that I cannot put in anymore
prs are highly welcome for this, but make sure to discuss possible implementations upfront, to avoid getting the pull request rejected
oh I mean that in case he manages it he could share it :)
I will probably go with the english voice control for now because there are already many working modules out there -
@maxbachmann
Hi, the modules get signals to act and it realy doesnt matter in with language u use the voice.By the way i am also interested if u get it working in german
yeah but you still need to train it for the language
We could get Around the issue of @witschi87 but we dont know yet what the problem actually is. When he starts his mirror with DISPLAY=:0 nohup npm start & it works, with pm2 start mm not, but i have seen a couple using it with pm2 already
@iMAGiC sry I my Time is pretty Limited due to my Bachelor thesis, but i will have a look if i can adjust the Existent Music player to Voice commands easily
@strawberry-3.141 Any news here? I have the same problem. It works with
pm2 restart mmbut not after a reboot. Error 1. -
Guys,
If you want to try a multiple languages and self hosted module you can take a look here: https://forum.magicmirror.builders/topic/6615/kalliope-assistant-mmThis module allow you to bind MM to Kalliope assistant.
hi guys, i’m a little over my head here, really not familiar with coding very much but i’ve got voice working and been able to tweak a few things.
what i want to do is probably very easy but i just can’t get it to work. i want to have mmm-voice control the default compliments module such that compliments begins hidden by default and i can say “how do i look” and the mirror will show the compliments module for 10 seconds then hide it again.
i could change the compliments to have appropriate responses and then when the user says “how do i look” the mirror will appear to answer them.
i was thinking of setting “HOW DO” as the mode command to control the compliments module and then “I LOOK” could be the command within that mode to show a compliment for 10 seconds.
what do you think? is this a simple task?
@dogfeet cannot tell if it is an easy task for you, it depends on your knowledge about JS and MagicMirror
I assume you read the documentation here
- in your compliments module you need to register your commands
- then you need to check for your command
notificationReceived: function (notification, payload, sender) { // 1. register module if(notification === "ALL_MODULES_STARTED"){ this.sendNotification("REGISTER_VOICE_MODULE", { mode: "HOW DO", sentences: [ "I LOOK" ] }); } // 2. react on command if(notification === "VOICE_HOW DO" && sender.name === "MMM-voice"){ if(/(LOOK)/g.test(payload)){ // unhide the module, // set a 10 sec timeout // hide your module } } }That’s all you need to connect your module to MMM-voice. Now you have to implement the comments
https:
Tried installing this today on a Dell Latitude E5500 running Ubuntu.
Seemed to install ok. Said my microphone was labelled 0
so entered that in config.jsNot getting any errors on running, but not getting a microphone icon anywhere on screen?
@cyberphox never put it on an ubuntu machine @cowboysdude and @Mykle1 did, maybe they can assist you here.
If the error log is empty, you can also set
debug: truein the config and check the debug log file -
@cyberphox said in MMM-voice:
Message me and I’ll try to help you out
@Mykle1 thanks man! helpful as always…it was Hello Lucy that inspired me to build another project with a little more power than my RP3…
No problem. See your chat messages so we don’t take up any room in this topic
@Mykle1, got any suggestions or pointers on how to get Alexa (or any voice assisted module) to work on Windows 10???
@justjim1220 said in MMM-voice:
A while back, I halfheartedly tried to get MMM-voice to run under Windows 7. The problem is the dependencies that are required, finding them for your platform (Windows 7). It may be possible but it just wasn’t worth the effort to me when success was not guaranteed.
On the other hand, MM runs beautifully under ubuntu. In fact, I wouldn’t use (or recommend) anything else.
thanks @mykle1 for the assist to get it to show up!!
You’re welcome.
